SC10 4x4 Thread
#6572
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
But there may be more to it than that. The chassis of the Losi is what puts the weight low, so does replacing that with a CF chassis make it drive like ass? Probably not.
#6574
The chassis of the AE is incredibly lightweight, so that adds to the issue of having the CG too high.
If you think about it, other than lowering the bumpers' position, there's no other viable solution to the CG issue.
Maybe using saddles making a 2S1P configuration instead of the classical 2S2P/2S3P? That would obviously need very high tech silicon molecular packs, which have nearly 2x the power density of regular LiPo packs... But they are expensive as hell.
Or probably using a 2S1P, ultra-thin pack with carbon fiber maiden case to make it as thinner as possible, to have a very very very flat pack that sits as lower in the chassis as possible.
But as I said, other than the bumpers, nothing that's viable on the short run can be done.
Regarding the 1406... Maybe with a very very short gearing (14/93) it can survive a full qualifier/main.
Not situable for this car. I tried a 2 pole, 14T Orion and the thing was scorching hot (enough to burn my fingers) after 4-5 minutes. I ran a 18/93 ratio, the same I run on the 1410. And the 1410 is simply cool.
#6575
Thanks.. i may try it just for shits n grins. Sometimes a smaller rotor can actually make it faster out of the hole because getting traction is easier.
Next question... If I start shimming the inner ballstuds, how far can I go before needing longer ballstuds? 5mm? These things have a metal plate they thread into, so if they are too far out they fall out.
I also noticed they tend to work loose. I'll use locktite next time.
#6576
Yeah, just pop it in and do some laps.
It might surprise you! Castle motors behave in a very unusual manner sometimes
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
#6577
he guy i have lawn darted my truck a few times and i think the chassis isnt as flat as it was new so i made a link to stiffin it up and then readjusted my pulleys but in order to keep the belt from skipping under hard acceleration i have to set it too tight which causes it to bind up in reverse and its got way too much resistance to the point that motor gets hot really fast . so i loosened it up and when doing so i noticed the pulleys were wobbling around so I ordered a new belt and the STRC aluminum tensioner pulleys and new bearings for the new pulleys . I may have jumped the gun but the pulleys are both real wobbly and im thinking this might be part of the problem . What are you fine folks doing to keep this from happening . and what suggestions do you have to remedy this . Thanks
#6578
the belt can't be too tight cause it will tighten under acceleration, you need some flex.
It does depend if you are running the smaller pulley up front.
I had belt coming off problems on the front, it might be tensioner or belt cover, it used to slip a lot, so annoying but i haven't run my truck in a while. I replaced the belt put back the 20 tooth pulleyand it seems to be ok.
#6579
And this is why I won't lawn dart mine until I don't get the links to finish the stiffener.
#6581
4-pole sensored...
For quals and mains... Do like![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
For practising... Do not like
![Frown](https://www.rctech.net/forum/classic_images/smilies/frown.gif)
#6582
Here ya go!
#6583
I don't know if this is an issue or not, hopefully someone can help out..... I noticed today at the track when i was doing some testing on my car stand that when I would give the car throttle the right rear would stop alot faster then the rest of the wheels, basically the other tires keep spinning and the right rear stops????? Is this an issue with my diff. or something else binding?
#6585
R/C Tech Elite Member
