SC10 4x4 Thread
#6121
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
You guys do realize they call it a slipper for a reason?
Seems to be the number one problem with the truck, my kit is fine, fastest laps I've ever done with a SC! Mine slips for about a second on a wide open launch like it's designed to do. The thing is if it's slipping to much then shut it down and adjust it before your pads melt! I believe most of the slipper problems are self induced either from assembly or roasting the pads and then they come on here acting like AE needs to do something. It's a slipper, its designed to slip.
#6122
Same here.
My pads slip the necessary amount, when I land jumps, when I floor the throttle, and so on. And most of the time is a short 'skweek' and then it kicks full power again.
AE didn't do it wrong. Users do it wrong by putting too much power through the transmission.
Don't forget that the slipper also protects the transmission, especially the pulleys.
Edit: And it's nowhere locked. Maybe 4mm from shaft starting. No spacers, no washers, no nothing. Plain stock.
#6123
my toughts exactly
+1
edit:typo
+1
edit:typo
#6125
![](https://www.rctech.net/forum/rctechv3/special/techelite_alt1.gif)
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Hm, maybe that would explain my why slipper works so amazingly.
Double checked and it's at (!) 2.5mm.
My pad is orange-ish instead of the classic dull white-pale yellow colour.
#6128
The new ones are tan, not orange anymore.
#6129
No clue, then O.O
Probably it works because I didn't floor the throttle straightaway with a loosened slipper, causing it to degradate very fast?
#6130
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
#6131
Thinking about it, I'll get a set of the new pads, just in case mines want to slip too much.
Can ThuderbirdJunkie point out where did he get his set?
#6132
Ah... My LHS guy is so stupid he didn't even kow what a SCT was.
He doesn't even have 48p pinions
![Embarrassment](https://www.rctech.net/forum/classic_images/smilies/redface.gif)
#6134
