SC10 4x4 Thread
#4726
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Ok just got this truck this week. Looking to start building it tomorrow.
Was wondering if people have been using the smaller 540 motors with this truck and if so how is copared to the 550 motor.
Reason I am asking is I have a 4.5 ballastic 550 and a 4.5 540 trinity duo 2 motor how would these compare to each other
Heat?
Run time?
Over all speed?
Also where can I get these o-rings everyone is talking about
How important is it to get the swaybars can't seem to find them anywhere.
Thanks for help
Heat?
Run time?
Over all speed?
Thanks for help
#4727
Got the Traxxas 12mm alum hex adapters from Amain. They include the pins and shims. I got eight screws in my kit but I guess four of them are spares, right? They are tiny so I guess they strip easily. Should I use both shims on each adapter between the bearing and the pin? Also, do you use any threadlock (blue) on the screws?
#4728
#4729
I'm having belt problems big time. Belt is slipping and at times it will get bound up in the front. I have the tensioners set for max tension. This is really frustrating.
Also the stock wheels let so much clay come inside that the tire grew like a balloon and was wayyy out of balance, it was wobbling something stupid! . Mind you I was racing on a wet clay surface.
I guess the DE wheels are much better?
I hate to say this but a friend let me drive his Losi and I liked it alot. It was so much easier to drive, I feel like I'm fighting my truck. Mind you I run on mostly loamy, clay rough surfaces. THe Losi didn't accelerate as hard but it jumped great and I could full throttle over our whoopie section and the truck stayed planted. I even liked the way it jumped.
#4731
I've got the DE wheels and they are nice, no holes inside the wheels and way less flex than the AE wheel.
Don't give up on it yet.....
Plus that's a tuff screen name to be rockin in the Losi thread....
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
#4732
![flaming mad](https://www.rctech.net/forum/classic_images/smilies/angryfire.gif)
![Frown](https://www.rctech.net/forum/classic_images/smilies/frown.gif)
#4733
I am having the same problem. Tried everything. Tight belt. Medium belt. Loose belt. New belt, pulleys and tensioners. Always kicks off when Im in the lead or getting close. Got it handling great. Just need to finish.I think its the wimpy plastic front housing that the tensioner is mounted to. An aluminum one would be much smarter. Why Associated every went to belt vs shaft I dont know.
Looking at the Losi also.![Frown](https://www.rctech.net/forum/classic_images/smilies/frown.gif)
I bet your right about the flimsy front belt covers/case.
Have you ever tried to bend the truck in a U shape? Simulating the front or rear having upward force on it? I did and theres' quite a bit of flex.
I could see the all the flexing having the negative effect of loading and unloading the belt quickly. Add braking into the mix and I could see the belt getting out of whack.
Someone needs to come up w/ a upper chassis stiffener.
Does it always seem to happen on landings or right after that?
#4734
hahah yea I'd have to ask a moderator to change my name or something LOL.
A lot of people were watching me closely and they saw the issues I was having and they were all saying that's why they didn't go AE because of potential belt issues. Very disappointing to say the least I was hoping to do better.
I didn't finish twice because of belt issues. I have a fresh belt on there with a new front pulley.
Honestly in the loose, wet loamy clay the Losi ran great. I hate to say it but I wish our truck was heavier and better balanced.
In my opinion it's designed for more of a smoother high bite surface. I run on the exact opposite.
#4735
Heat?
Run time?
Over all speed?
Thanks for help
Heat?
Run time?
Over all speed?
Thanks for help
#4736
1. make sure your front adjustment pulley is on correctly, I had mine backwards
2. check the inside of your front cover it may have build up or be distorted from the belt coming off, I actually replaced the cover on mine it was pretty bad.
3. I put a new belt on mine.
Hope this helps
#4737
Haven't had any belt problems yet, but I'm about fed up with one issue my truck has. On big jumps, it jumps way nose high, and even slamming the brakes won't bring the nose down far enough. It's hurting my laps times on layouts with a big jump or two, as often I have to roll the jump because the truck won't fly level and nail the landing. Rebuilding a used Durango now, and if its more stable and jumps better, the AE is going away.
#4738
didn't tape, but I'll try that. My lhs doesn't have the DE wheels which I want.
I can't believe that the belt has caused you to DNF. Our indoor track is over ran w/ SC104's, I've yet to see a belt cause anyone to not finish. Not saying your lying, I just havent' seen it yet.
I thought the same about the ae truck is good inside and the losi better outside. Until I ran mine on a blown out 1/8 track, it worked way better than I thought it would. I beat both the Losis there and 2 1/8 e buggies w/ the SC104x.
Try bracing the top of the chassis somehow, or someway to brace the middle belt cover.
The losi truck is old news, 3 diff buggy w/ a truck body, stick w/ the SC10, it'll come around.
What tires are you running outside?
#4739
The rest I built box stock and threw out most of what I've read on the forum and went to the track. Well my lhs had a scte in stock. If you were to know me you could understand how much this pained me but I just wanted to enjoy my Sundays and not fight my truck. I put the scte behind the counter for after race day.
Well my race day was awesome .. the truck did a total 360 from prior weeks at the track and I cut my lap fast times by 5-6 seconds a lap. There is nothing I can do to make me drive better so that issue isn't going anywhere just yet.
Don't give up on this truck because when you do get it right you wont be disappointed.
#4740
