SC10 4x4 Thread
#4186
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
ok thank you very much clear that up
#4189
The cover does not rub much. I heated mine up a bit with my heat gun and set it over a small round container and push down on it a few times to stretch it out just a little. It takes a bit of heat from the heat gun to do this but within 10-15 minutes I had no rub. You will not regret this upgrade! It is the best change I have made to the truck!
#4190
I just broke down and placed the order for the clutch basket. The pictures look like 3 HD pads are used. Is this best practice?
Mac, beggers can't be choosers with free shipping but I'd appreciate it if you could get it out ASAP. I'm hoping to get it installed before Bring the Heat.
#4191
#4194
Just curious, but have you been running it long enough to notice longer pad life or is it around the same.
Trying to figure cost savings, mod over stock setup. You can buy 6 sets of slipper pads for that...
#4195
I have no affilation with the maker of this upgrade either as I am only a consumer and these are my thoughts on the upgrade. I would never go back to the standard slipper after running it.
#4196
#4199
The standard Decoupled slipper what I have found is that the rear drive needs a much heavier load and causes the entire slipper to heat up and glaze both front and rear drive pads.
Once you install teh clutch basket now the rear has the drive it needs and I have found it helps the front drive last longer as well because of the less heat and overall slip.
#4200
You guys with the basket using regular slipper pads or HD pads. I just ordered one. Also will the gear cover from the B4/T4 fit without heating.
