SC10 4x4 Thread
#3601
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
turned 3 turns out, giving Ryan C setup a try this coming weekend and for front 6mm long, will adjust as needed after tuning down outdrives on lathe.
With limiters applied I still have more up travel than my 2 wheel drive, about 1 3/4 inches.
Steve
#3602
theres a guy on ebay bizzare hobbies he has some sway bar kits it said 6 available i just bought two cost me 35 dollars free shipping look pretty nice the med bar is anodized blue. check em out tell me what you guys think. i wasnt fast enough to catch them at tower and too lazy lol to build them
#3605
#3606
What I like about using fuel tubing is that it gives some Cush on the really hard landings that may spit out the clips (that I'm pretty sure are meant to be used as downstop shims).
#3607
http://cgi.ebay.com/Associated-SC10-...item3a676ecc25
Here's a link to the Hot Racing swaybars on ebay
#3610
If those are the wires supplied, I don't think they'll fit. They look too narrow across the perch.
#3611
That's odd they advertise the same bars for front and rear, the bend angles are different on F and R.
#3615
Don't remember if I saw it on here or what but someone suggested the 3Racing heatsink/fan combo. I mounted it up and it seems to fit pretty well. I added some ball stud washers under the fan plate so there is no chance of contact on the motor B terminal. Haven't run it to see if it actually helps with temperature. Hopefully tomorrow.
http://www.thetoyz.com/cart/thetoyz_...ame=HEATSINKS#
