SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Silver
using Reedy Sonic 4.5 550 12p/62s 30 degree timing
Lrp FLOW ESC
Lrp FLOW ESC
ok i was able to try a c diff out on a 4x4 sc10. i have the vts and i am a way better driver than the guy that had the c diff. i run the vts in mine. he would not let me take it out of his car to put in mine which sucked. he did let me drive his car which i might say sucked big time really cheap radio and gear no steering at all lol. tried to give the guy some pointers but he said he new everything lol even though i had lapped him and some other this weekend. with the same truck alomst. im not sure if it really helped on a lose track or not cause of his car so im going to buy one and put it in mine and see what happens. it almost seem like he a lot more wheel spin then i did and would not hook up but then again that is probably his set up with maybe one to many pins in the cdiff. i run my vts lose. and now i think he is out of stock which bummed out. any way any body run the novak system 4.5. i actually just found a sweet spot for my home track running 62/ 13. i top out just before the turn on a 180 foot straight which is sweet. i was at a 62/12.
Yeah, hard to compare any part with a different trucks parts & setup.
More wheel spin could be setup, too many pins, not enough pins... so many different possibilities. But in general, the slipper will slip, the C-Diff will put all the power down and diferentiate front to rear power output. It's up to you whether you want a more equal 50/50 power distribution (more pins) or if you want the diff to send more power to the end with the least traction (less pins).
Same theory as a center gear diff, this is just a ball diff.
While your waiting try the VTS with a extra pad on the outside & the heavy duty yellow pad behind the spur.
Will be smoother & more traction ..
less wheel spin
inexpensive too
less wheel spin
inexpensive too
what r part numbers for pads.
If you are sticking with the pad setup, based on what Shark recently commented on, give the RC Shox ones a look
louie
Here yeah go ...
I listed the heavy duty pad and recommend to use behind the spur gear for improved performance ...![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
Heavy duty pad #91170
VTS pad # 91177
Here yeah go ...
VTS pad # 91177
Guys -- about to rebuild my shocks & set them up for indoor, med sized smooth clay track w/ high traction. After searching this thread I noticed 8mm shock limiters seem to be the top recommendation. As this will be the first time I set them up without boots wanted to get a little clarity on shock limiters.
Should the limiters be below or above the spring cup?
Can I still use the shock bumpers (part of ASC91070) & if so would they be counted in the 8mm measurement?
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
Suggest no limiters inside or out for best performance ....
Can use just 1 of the rubber bumpers on the outside of shocks for better wear & tear if you like ...
Place the bumper shim on top of the spring cup .
Thanks WC, would those track conditions also call for shocks mounted inside hole on F&R arms / outside hole on F&R towers? Seen you post about that setup before. Right now I have shocks mounted outside F & inside R arms / middle hole on F&R towers.
What weight is considered lite. I am not racing a ROAR event just club racing. I know that 2505g is min weight. How lite have you guys ran.
8.0 540 motor, 12mm shocks, slammed srevo, lowerd chassis brace, no belt cover, alum screw kit, ti shock mounts, cut bumpers, std team slipper, clicker not locked, shorty pack in line, esc in line behind battery on its side, 2290g
my ride is at 5.7 lb right at the moment can make as low as 5.2lb with out any added ballast & using a shorty battery...
Use the middle hole on the front shock tower .
Rear shocks
use inside hole on arm & outside hole on tower..
This is where I have running for med traction indoor clay..
also unscrew rear shock eye 1 turn
20mm ride height
