SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
you may want some garodiscs then, from what people have reported, you don't glaze those.
Hey I tried that set up on tuesday and really thought it improved the truck by making the front pull better/more.
Now my question is what is the perfered way to get the glaze off of slipper pads? and how does one propperly set up the slipper tension.. also is there a different spring on the one in the photo mine is black.
Can clean many times and nothing beats the yellow pads performance on the track ..clean the pads about every 30 runs .
Silver Spring is the Sc10 4x4 slipper spring (91090) .
black spring is for Sc 2w (7486) suggest you stick with the black
Adjust the slipper by screwing the lock nut just before it touch's the nylon on the inside of the lock nut & use lock tight to help secure the nut .
Mirek
Use #1779 FT servo mounts
Ok so I am a little confused about what is a Quad pad. In your photos WC I see only three pads. Are you counting the pad on the front side? Your instructions stated to add one pad and one disk which is adding to the two pads in the FT kit.
I installed the additional pad and the performance was not that much better. I think it is time for the RCShox Center diff for me.
Are you all using the RPM arms? I am thinking a lot about chassis flex on this vehicle. The RPM arms are not known for rigid performance. I am thinking about Carbon fiber plates for the arms as well like the 8th scale boys are using.
Another item I was thinking about was the rotation of the motor. The X-Factory 2wd kit has a 4 gear trans to get the motor rotating opposite to help traction. Do you think this chassis suffers from the gyro effect of the motor? Most 4x4s are running a motor in-line with the chassis. On-road cars have the motor more centered in the chassis which is mostly for weight balance.
Easy to run the slipper to tight.
If you have threads showing above the lock nut ?
Its too tight ....
Should be easy to push the spur by hand to slip.
The main advantage the Quad VTS has is its ability to be run very loose .
This is why VTS brings more traction ,smoother acelleration & handling.
I must be the rare case then because I feel that the slipper is keeping me from accelerating as quickly as the three diff trucks. I put the bigger (HD) slipper pad on the inside for the front drive and that really helped my loose condition coming on to the straight away. I beleive that it gave it more drive to the front and pulled better.. Then I put in the extra pad on the VTS side and it seemed to pull harder still over all. BUT I want more and the slipper seems to be coming off pretty warm..
Would the AE coupled inner plate or the exoteck front locker make any difference in the way it pulls off the corner?
So the Black spring from a 2wd sc10 is the spring to run on the 4wd?... I checked mine again and it is silver.. So would the Black one have more pressure?
Should the front lift when you hold both rear tires and blip the throttle like a 2wd buggy should?
I am doing really well with the truck at JCP rc raceway but am having troubles when I am in traffic. It seems like I cant accelerate like the three diff trucks but I am as fast at the middle of the straight.. Any thoughts?
Those of you that are going through the chore of adding pads and sanding with 120 grit and all of that , just install garodisc, they never glaze or lose adjustment EVER!! ANd will handle any amount of power or abuse you can put to them!
Here's another interesting mod for the Sc10 4x4 for every to enjoy.
Its very reliable & performs awesome ...
uses one FT servo mount & one B4 Carbon C hub
Look carefully and you can see the mount screw underneath on the top deck . image #499
A kool mod....
A kool mod....
![Cool](https://www.rctech.net/forum/classic_images/smilies/cool.gif)
great from MantisWorx there.
By the way Marcus, when you compare the RC Shox Center Diff to a VTS slipper as far as the VTS Slipper being run "Tighter" versus "Loose", would a correct comparison to the Center Diff (V2) would be how many pins you run, with the more pins making it "tighter"?
I think it will be fine. I was getting like 12 minutes on some 5200mah lipos with a Tekin Pro4 motor.
ok thank. Does any one use the 19 over drive clicker for the front. i put mine on to try it in the street i can not tell if i like it or not. i figure if my lap time suffer im gonna go back to running 20/20 locked. i have the 19 overdrive locked down as of now. but next race not tell june 9. the 19 should give more front wheel spinn right and turning.
- push on entry
- on power steering
It has been proven that the slipper can obviously work but its a compromise. It has also been proven that a center dif can also work, in the end it just depends on preference. But a slipper will NEVER work good on loose conditions where as a center dif will work on both high bite and low grip conditions.
