SC10 4x4 Thread
Thanks for the quick replies. With the recent talk going on in this thread, I had to clarify.
[QUOTE=SC Shaun Too bad we missed you today.
[/QUOTE]
Just1more , Here's your nibble..
you know , 1 piston + 1 piston +1 piston makes three pistons....
[/QUOTE]
So I got the v1 center diff from a awesome member here for the price of shipping, (thank you) and placed my order for the v.2 upgrade kit from rc shox hopefully Mantis can get it out to me tomorrow and I can have it by thursday and install it for the friday night races next week. I can't wait to see what everyone who has the center diff has been saying first hand, controllable power on demand, and easier to correct in the air. I want to change my rear springs to the front blue springs as I'm told they work better with the exotech chassis, but I saw someone post to use the limiters and adjust ride height? If I use the c clip thingy I hear they pop off so can I use fuel line? If so how much do I cut? I just got a new digital caliper last night and am dying to use it lol.
P.S. if someone made a quick vid on how to change the front springs to the rear. You'd kinda of be my personal savior lol
Aside from the (expensive center diff) what are you guys going to combat overheated slippers?
I have the FT with the VTS, and a high torque inner pad. 4-5 minutes into a race the slipper over heats, and starts to give up when needed. I'm going to try a locking hub at some point, I just haven't gotten around to it.
Tech Legend
- Shock Spring put on first
- then C clips on top of the eyelet
- Then bottom shock cup OVER the c clips
- Then any C clips (you may put these on with the other c clips, just make sure they are separate) that you are using to limit up travel.
Sal
hey guys i wanna get back in to sct 4x4 next year and i wanted to know if i put a steel middle bit in the sc10 4x4 would it make it handle better planet on the ground or should i go somethink like the tekno sct but i really like sc10 4x4
tighten slipper
1/4 turn at a time
do not lock it up
replace slipper lock nut for new one cus it may be the real issue
I personally can run with out the spur gear cover on .
Helps the slipper & motor run a lot cooler ...
cooler motor & slipper improves performance
