SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
First, I don't see any advantage in removing it. Weight is practically nill.
Second, even though the exotek may provide enough stiffness, I like the bracing up top as well. I think it can only help provide even more.
Third, it makes a nice place to zip-tie my wires to!
I do
I took mine off, due to running on a med to high bite clay track it made the truck too stiff and it bounced around a lot. Also helped keep the rear end planted when I took it off.
Thanks guys for the comments! Keep'em coming!
I've got one more day of off road then its on to indoor. So I was curious about the pro's and con's of keeping the brace.
I run the exotek chassis and do not run a brace. I have debated trying it, but like how the truck handles right now, once I fix the power issue I should be set.
I'm getting back into it after a little time off.
I had a Sc10 4x4 for a little while but never really experemited with tuning it.
I had the FT manual specs.
I was curious has a setup they can post or a setup sheet I can download?
I will be running Exotek chassis in saddle pack config. So I know shock weights and springs will be different, track condition is Med to Low bite outdoor will likely run +3mm wheels.
Thanks if anybody could help me out or add anything else I may need.
The RC Shox Center diff also shines in low bite conditions from what I have experienced. Worth the money in my opinion but if you do want to stick with the slipper setup, I would suggest going with whatever is recommended for diff oils stock, I think thats 20 or 30K front, 5K or 7K rear. if you do the center diff, for oils I am really liking 7K front and 5K rear pretty much everywhere. Some even run a square setup of 5K all around.
RC Shox dual stage pistons also work REALLY well on bumpy stuff.
I do have a setup from the conditions I ran on that I liked I can provide you with if that would help. I posted it on here but if you can't find it let me know.
Anyone try this on say carpet and can report back the differences they felt as well as how they liked it?
What shock 0-rings you guys running? Are the trackstars good? Saw em on a diff forum. Where do you get em?
i personally ordered a couple of sets right away and when I did the rebuild for oil change went with them and haven't gone back.
I've ran the original Trackstar set I bought in july 2011 to today. Smooth as butter and have never leaked once.
![sneaky](https://www.rctech.net/forum/classic_images/smilies/sneaky.gif)
