SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
ill give you wc for it lol
4X4 SC seems to be dieing just as fast as it started at my track, only two cars today, and after the Losi broke we didn't bother running one car, lots of guys have the trucks, just don't seem to be bringing them on race days.
Trader Rating: 18 (100%+)
![Thumbs up](https://www.rctech.net/forum/images/icons/icon14.gif)
Well the 3 denotes 3 degrees of toe in. The 2 denotes 2 degrees of anti-squat. Per Associated, less ant-squat lets the suspension work better over bumps but will sacrifice the ability to square up under power. Having run both during infancy testing with this truck,I have found the 3-2 works the best all around for this truck. I hope this helps![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
Mark Smith
Mark Smith
Good lines.. R.B.
Mark Smith
Mark Smith
Good times.. R.B.
We are still suffering from a major hangover from the Show Down...
Later this fall the SC 4x4 class will be kicking hard ....
Having a blast running the B4 anyway terrorizing the track with PINK preparing for the Sc return ...
wc my truck dont like a 15 tooth at 62. it has a novak esc gtb2 esc 4.5 550 iam back at 12 tooth. my esc was way hot motor was at 150 in ten min
You are going full speed most of time on the street .
That's makes for the extra heat .
Its why I suggested you keep a eye on the temps & try not to run the truck more 8 min..
BTW
think you said you are seeing 140 degree ?
That's not that hot ...
Hot is about 180 to 190 for the motor ....
160+ hot for ESC
my yellow temp light came on the the esc it says iam over the safe temp of 150.
thats how i drive in the street. i like the 12 better.
I know the showdown coming back! I really wanna run this time and I just got the b4 having a great time with it. Not sure I I should shelf it till after the showdown? I need to drive the 4x4 for a while to get in the groov. Right now I'm just 2wd buggy mode. What do you think ?
