SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Well lucky for me I put in a brand new rx8 and mounted it on the left side of the chassis without hacking the fan. Back up n running. I'm ready to continue testing and working out the bugs.
Marcus I never tried the v2's so that might be the problem. I dont know if they wore out or what but it's night n day difference going back to stock. The truck has a tighter feel now and that's what I need.
For the record I put 20 grams of that brass weight that Maifield uses in the front and that seemed about right. I may add another 10g.
For the record I run the exotek chassis.
I'm just happy that this thing is running again. Gotta love my lhs for hooking me up and keeping me running. (prob cause i spend so much $$ there lol)
https://www.facebook.com/photo.php?f...type=1&theater
Thats exactly what the V2 design changed, tighter tolerance on the shock shaft and piston to bore clearance. Those changes "tighten" the truck, i promise V2's will out perform your stock especially on the kind of tracks you run on!
ahh wish I would have known. yea truck felt like a boat on water LOL.
BTW gonna need a new v2spur, my teeth are getting worn out. worst case scenario I can go back to the v1 to stay running.
One word of caution ... the slot below the wire tabs lets a lot of dirt in. I have been using silicone caulking to cover the hole and it has been working great for me.
the 4600 has a different wind than the 4000 and is actually smoother supposedly.
I run the 4600 and gear at 14/60 with current limiter at around 45-50 percent because I run outdoor.
I also have it set for about 80-85 percent power. On full juice the bish will fly.
If anyone has a set of sc10 4x4 shocks laying around, let me know. I'm in need of a set with springs etc. thanks guys. Pm me.
I liked the v1's I got in December, but the v2's that you swapped me out for did feel better and must have been different because my oil weight went down 5.
Yeah, not as much of a benefit indoor smooth, but you do get a little more pop off lips of jumps that are immediately after a tight turn.
Beat up outdoor, absolutely better than single stage from my experience.
Thanks for the help guys with the FT kit! Has anyone here actually converted their non FT to FT using the AE kit?
It seems that people have had issue's fitting their RX8's in the chassis etc. I'm just looking for any pointers. Since I will be picking the kit up ASAP. I'll also probably just stick with the stock chassis as well for now. I will also need to pick up some saddle packs. Any recommendations?
Thanks!
Thanks!
Trader Rating: 18 (100%+)
Can anyone explain to me how the 3_2 And 3_3 rear blocks differ affecting handling? Thanks...
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
Mark Smith
![Cool](https://www.rctech.net/forum/classic_images/smilies/cool.gif)
