SC10 4x4 Thread
#2836
#2837
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I just found I have the same problem. Was going through everything after racing yesterday and noticed that the front outer bearing seals were worn through. When I reassembled everything and pushed the wheel all the way on there was binding. I pulled the hex back a smidge and it was free as can be. My thought is that this is happening when the axle nut gets tightened too much. My rear ones were fine. Gonna start looking for a remedy. This could be why I was having temp issues and why it would lawn dart off of jumps unless I stayed on the throttle at least a 1/4. I do have a tendency to over tighten things, so I'm pretty sure that was the cause, though a solution needs to be found so it doesn't happen again.
Maybe someone has had this problem and has found a remedy, if so, please post..
#2838
What pistons are you using in the Losi 8 shocks? I'm getting a full set of new Serpent shocks for my e-811, and picking up a used SC10 4x4 today. I might compare lengths and try the new Serpent shocks on the AE. Knowing your pistons, and the spring rates of Losi red springs will give me a good starting point. Thanks.
Congrats to Cameron and Darren for the 1-2 win in NW SC Nats. It was worth running the C-main so that I could watch the action in the triple A-mains.
![Embarrassment](https://www.rctech.net/forum/classic_images/smilies/redface.gif)
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
My truck never failed me once all weekend at the Nats and at my local track today. I TQ'd and won 4wd SC today. Three days solid of some great racing, practice and a few big hits in there as well. Just keeps on trucking.
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
#2839
so is anything gained/lost when u run a 540 can as opposed to a 550? im running a 550 but i see some guys on here talking about running 540...dont they heat up faster?
#2840
![](https://www.rctech.net/forum/rctechv3/special/techelite_alt1.gif)
Location: Norwood, OH...and CCRCR and The OhioRCFactory
My C-main race from yesterday's NW SC Nats.
No swaybars
Losi 8ight shocks
Castle MMP/1410 3800kv geared 16/62
XP1015 servo
Venom 60c 2s
Barcodes in orange compound
Locked clicker
30k front/ 3k rear diffs
I ended up 19th overall out of over 40 drivers in 4wd open class. Lots of SC10 4wd rigs at this event with a few scattered Losi/Hyper/Jammin/Slash trucks.
Thanks to Cameron Kellogg for taking a break from slaying the competition to shoot the vid for me.
I'm the blue truck with the white roof if you can't figure that out.
Click the vid for HD.
No swaybars
Losi 8ight shocks
XP1015 servo
Venom 60c 2s
Locked clicker
+ YouTube Video | |
#2844
Can you post a direct link? I can't see the video on my phone.
#2846
Looking good!
#2847
Here is my video from today at my local track. Only four guys showed up to run 4wd SC and one guy broke during the last heat, so just three of us in the main. Everybody else was running truggy and buggy. ![Frown](https://www.rctech.net/forum/classic_images/smilies/frown.gif)
Only change to my setup was tires. This track is regular old loamy dirt. Proline Gladiators work awesome for it. I made a few bobbles and the wind grabbed the body on a couple of the bigger jumps, but overall not bad for my first weekend with this rig, IMO.
I went through two MMP fans today. Ended up just yanking it off the ESC to get more air to the heatsink. It was coming off the track at about 170 degrees. Gonna have to find a better fan or the dirt from this track is going to kill all my fan cooled speed controls. ![Embarrassment](https://www.rctech.net/forum/classic_images/smilies/redface.gif)
+ YouTube Video | |
#2849
Registered User
![Exclamation](https://www.rctech.net/forum/images/icons/icon4.gif)
if im using the 1/8 lrp motor with the big shaft and my spur is the little teath what do i do dose somone make a small pitch pinion with a 1/8 shaft whole
![Confused](https://www.rctech.net/forum/classic_images/smilies/confused.gif)
#2850
