SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Thanks I'll give it a go.
long front like helps to on tration roll +1 on 8mm
Anybody else boosting an rx8 and a 2 pole 550? Whadda ya settings?
I liked the 8mm mod and will probably put it back on. Has anyone used less than 7mm on the inside? What were the results?
yeah, I agree. I just separate it out
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
6mm felt the most consistent, but with 7mm ran faster laps.... 8mm was too much and 5mm was too little for me.
less = more camber gain?
So I went to 4seasons rc Sunday. Indoor tight clay track high traction. I tested the Exotek front locker hub all day. Back and forth on and off 3 times over. I have concluded that I prefer the stock v2 on the factory team over the exotek. The exotek made the truck feel more inconsistent and I had less control, cornering felt sloppy. The stock v2 was smoother overall and more consistent. Stock was faster by nearly .5 - 1 seconds. Didn't notice a difference between the two on the straight away.
Anybody want to buy a used one?
yeah, it is probably not needed indoors. I never really had too much of an issue on indoor clay with the stock vts. But on loamy outdoor, I liked it.
Have to keep in mind that with the Exotek, you should be running different front diff fluid than you would with the V2 diff. Other wise, steering will suffer
ok, lets talk about that. Has anyone found out which diff oils work best with the exotec outdoors mixed traction? loamy to wet soft clay?
I was reading some where (not sure if it was here or in another forum) that some people were running like 10k front and 5-7k rear
