SC10 4x4 Thread
lol, I never understood it either. I guess he runs 8 springs.
Probably Inside/Outside hole on the arm where the shock mounts. Guessing:
Front spring Yellow on outside hole, Back spring is a Front Blue on the Inside hole
Yup!
Sorry for not clarifying. Middle on tower both f/r.
Ok, I'm running blue ft and ft white rear. Putting them in those bottom holes gives a balanced car?
Cool. Thanks.
I tried putting 60g of weight in the front as per an AE setup sheet and the rear wheels would leave the floor when I braked plus it nosed dived like a bitch on any jumps.
I don't have any scales but could someone that's got similar electronics post up what weight they added please.
No exotek chassis, Tenshock motor and a 120a hobbywing speedo on the other side with FT saddle pack batteries.
Thank you.
Cool. Thanks.
Thank you.
Both motors are really good, I have the tenshock sc411 4600kv and it is a beast of a motor! From what I can tell (no electrical engineer) they are built very well and well worth the money. If I had unlimited funds I would probably have gotten the Pro4 but I am trying to stay on somewhat of a budget so I opted to go with the cheaper option. I previously ran an SC4x 4.5t and no matter what I did that thing didnt have half the rip of the Tenshock.
I started getting beat by the pro4's but didn't want to spend the $ on one.
Tenshock came to the us and I picked up a 4600. Holey smokes! That thing rips.
well worth the $ IMO and only the 1/8 scales can out run me on the straights... and barely.
To the other post, to my knowledge, Tenshock's are manufactured in Germany and distributed from China.
Well, Using my math (just a formula I got offline so It could be wrong, measurements are correct.)
A Blue spring up front on the outside hole gives a wheel rate of: 1.267 lbs/in.
A White spring in the rear on the inside hole gives a wheel rate of: 1.289 lbs/in.
That does not make a lot of sense. Designed in Germany and build in china would make more sense. I have no idea how any of you can even handle that power. I have a tekin 4.5 and it spins 4 wheels everywhere.
All things RC come from China so maybe that was their thinking on distributing from there???
This truck absolutely handles the power. Outdoor & indoor... need to be a little easier on the throttle outdoor, indoor, punch it!
Wrong tires for the track, 4 wheel spinning. Correct tires, 4 wheels scrubbing
I love my Tenshock.. Power is very manageable to me. Closest thing I have found to the Jp mod motors I used to run in Truggy.
I think he needs alot more than the center diff! lol!! j/k
I was using Rb's and Novarossi p5's and couldn't grasp why anyone would spend the extra money on those sexy blue headed jp's.... Then I drove one! I have to say they were the most linear engines I ever came across. And you absolutely could not out run one. Got really good run time to boot. Needless to say after the first we never ran anything else on our Mugens.
Cool. Thanks.
Thank you.
Cool. Thanks.
Thank you.
I had 33g (I think) but I'm at 28 left of servo now (exoteck, 550 can, stick pac).
i had 3oz in the front and didnt feel it was to hard to drive. i did go down to 2 oz though just because i felt i had a little to much weight transfer.
