Like Tree5Likes
SC10 4x4 Thread
Old 07-19-2012, 11:38 AM
  #26821
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Jeff i just sent you 5 bux for saying that!! LOL
MantisWorx is offline
Old 07-19-2012, 11:46 AM
  #26822
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Originally Posted by Wild Cherry
Put the VTS slipper back on and then compare ....
I have it installed as well. This exotek thing just replaces the inner pad and plate. The vts basket is still in place on the outside. So they work in tandum. I'll let you try it tonight if you get to trcr. You can put it on your truck if you have it there. Just takes a sec
ryanpatrickgore is offline
Old 07-19-2012, 11:53 AM
  #26823
Tech Legend
Wild Cherry's Avatar
Meant replace ft drive back to slipper pad , rather then me try ?
You switch back & drive , I watch .....
Then we will put the Exotek back on, then I watch again ....
Lap times will be the judge , not me .....
Good to see you testing ........
Also will be happy to try your ride a lap or two & TY for the offer to try the Exotek..
Wild Cherry is offline
  #26824
ilanstylz's Avatar
Trader Rating: 142 (100%+)
Here is my opinion on both the exotek and center diff, but I will state I am no expert with rc's in comparison with Mantis and others so take it for what it is.
I've owned both sc10's from the team kit to factory team kit, I've done upgrades consisting of MTK basket, rcshox garodisc's for both AE's clutch setup's, and both V1 and V2 diff's.........
What I am currently running now is the exotek inner hub with the VTS slipper and rcshox garodisc's, and the honest truth I'm loving it. Its putting down all the power I need for the front and rear, and to me is performing the same as the V1 center diff (now that's just my opinion). I do have the V2 center diff and the only reason why I'm not comparing it to everything else is because I've had bad luck with it, and its solely 100perc. my fault. Both times I tried it I locked the nut down so tight I'm sure I was bending the top shaft to where I could not get my gear mesh set properly. So I always ended up putting back the exotek/vts/garodisc setup back on and only having to tighten the nut barely past the threading and I had all the power to the front and rear I needed for my local track.
So to me the exotek hub along with the vts slipper and garodisc's is just what I prefer to run, not saying the center diff is better or the setup I run is better but I just like how my setup is and don't see a need to change for now.
My point is if you feel the need to spend the money on the center diff then go for it, its a great product and from what I've read on here and other forums from those using it are really liking it, but if you want something that IMO can work just as well and don't want to dish out the extra cash then try the exotek hub w/ vts and garodiscs and you could be just as satisfied.....
ilanstylz is offline
Old 07-19-2012, 11:59 AM
  #26825
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
JEFFs SC10 is offline
Old 07-19-2012, 12:05 PM
  #26826
Old 07-19-2012, 12:14 PM
  #26827
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
My laps will be better when the rear stops trying to go faster than the front, lol.
Wildcat1971 is offline
Old 07-19-2012, 12:15 PM
  #26828
Maddog94's Avatar
Trader Rating: 44 (100%+)
ilanstylz, what you are describing is exactly the setup I plan to use.
I have the Exotek locked front and I'm waiting for my Garodisks to come (may be here today for all I know) which I intend to use for the rear slipper.
Hope this works out!
Maddog94 is offline
Old 07-19-2012, 12:17 PM
  #26829
samuelsonmark71's Avatar
Trader Rating: 22 (100%+)
run the front 19 overdrive gear?
samuelsonmark71 is offline
  #26830
ilanstylz's Avatar
Cool post up your results after you've tested them out, so I can see if its just me liking it or not lol.....
Old 07-19-2012, 12:23 PM
  #26831
tried too. belt is to streched, the tensioners were all the way down and it skipped. I will try again once I get a new belt.
Old 07-19-2012, 12:25 PM
  #26832
If the rain holds out, I will be giving my exotek some track time tonight. /cross fingers
Old 07-19-2012, 04:21 PM
  #26833
Mizchief's Avatar
Doesnt get any better than this!!
http://rcshox.com/shoxshop/catalog/p...products_id=58
Install a center dif and problem is solved, your complaint is the number one problem with the truck on loose conditions, the center dif has been proven to fix this, which is what i designed it for! all of the tracks i run on are loose and blown out which are the wort conditions for this truck.
+1 on center diff. My only complaint is that it's a pain to work around if you need to change rear diff fluid, however iv'e been running 5k/5k with the center diff and it's worked with me on all tracks so far, so I don't really change oil at t the track very often.
I've tried VTS and didn't like it as much, back end would come around much easier to where I had to be careful with the 4000kv pro4, with center diff I can hit full throttle and keep it going where the wheels point no problem.
Will be upgrading to the RevTeck 4800kv & RX8, gonna be a rocket!
Mizchief is offline
Old 07-19-2012, 04:31 PM
  #26834
Jake S's Avatar
Trader Rating: 67 (93%+)
can you put beadlock rings on any rim? not looking to use it as a beadlock, but more for the "look"
mostly want to know if anyone has done it to jc hazard wheels.
Jake S is offline
Old 07-19-2012, 05:59 PM
  #26835
JEFFs SC10's Avatar
I took my truck on the street with the 14tooth pinion and the pro4 4600 with the epa at 85% it is still super FAST! Wayy too much for the dirt.
racing tomm night, can't wait.
