SC10 4x4 Thread
Sounds like one of your top shaft spacer isn't seated right, inside the gear box. Part # 91017. Page 12 of the FT manual.
hmm, why would that be the cause. If that were it , the shaft would bind no? the spacer sits between the bearing and the gear. If it were missing that would be an issue. But I would think with case would fully seat the spacer once assembled, or it would bind or cause the case to not seal correctly for sure.
I dont have the truck in front of me, but "if" he did indeed install everything correctly, I would still put the old top shaft in, reassemble making sure it is 100% correct and see if the issue persists. You could also compare the shafts side by side to make sure they are identical.
Then use the 2 of the .2 shims under sun gear only ....
Pin should fit just fine , but also check to make sure the out drive O-ring is seated.
If not, can make pushing the pin though more difficult...
Ah, I figured it was something like that. I forgot that AE made the coupled inside hub. It makes sense a new shaft would need to be made. Does anyone really even run the coupled config? Also, is the exotek inside hub coupled or decoupled? I would assume decoupled, just no slip front end.
Snaf,
I was reshimming my front diff last night and was thinking of you. lol. When I work on the drive line, I check for binding every step of the way. I think you said the rear is binding. I checked my front and it was free rolling. But I remembered something while I was checking it. The tranny screws should have a washer on them to limit how far they go in. If they go too far they will rub on the pulley or other near by moving parts. I will be taking off my rear pulley when I install my exotek clutch locker and I will see if mine was like yours. In the general case, when ever you build a car, always check every moving part for smoothness all the way through the build. Hinge pins, shocks, tranny and etc. This is why I hate buying used cars. I have no idea what yahoo stuff the previous owner did to the car. I always end up tearing the used car down and fixing everything they did wrong. Anyway, check to make sure the tranny screws dont extrend past flush on the motor plate.
I will hopefully be working on mine tonight also. Since my exotec hub is in. Going to reshim and do a diff tear down...ugggggggg. I will check my freeness once i get my rear pulley off.
anyone going to the sc nats at rcmadness in Connecticut in early August ?
lol, I have a half serious question. Where does the diff lube go? I put 30k lube in my front diffs 7 months ago. I read to fill half way, but i filled 3/4 full , let it rest and put it back to 3/4 full. This week I go to change the diff oil and it seems like 20% of the lube went away. It is not in my tranny case, no lube residue anywhere outside the diff. I am assuming it just settled into all the nooks and crannies of the diff. That being said, should you let the heavier diff oil settle into place a long time before closing it up?
i have like 4-5 threads showing... with the but off.. with the motor backed off.. i gave it a good push and it went about 10 feet.. everything is freely moving and smooth.. super quite last time i drove it with all the old hardware on.. all i wanted to do was change the top shaft out.. and this is my problem now.. ive been working on the truck for over a year now and im in a bind.. this is so weird!
Glad to report I have sold my train wreck of an experience sc104x4
Compared to my other truck losi scte it was rubbish
I did all the usual associated upgrade kit just couldn't get the truck to point straight on our outdoor track was nervous under powet and nervous off power!
Hell I even wasted $50 on the rcshokz centre diff ( very minimal difference)
Bye bye sc10 glad your gone!
lol, I should find a losi at the track and drive one see if it is all that.
i actually love my ft sc10 4x4. got the center diff and exotek chassis. it's a rocket. i'm not the best driver and still trying to improve. but, i have a combo of numendahl's and hartson's setup. let the fast guy at my track drive it and he immediately laid down the fastest laps at the track. this truck is sweet.
