SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
You don't need them on the hub, you need them for the shock tower. Almost everyone is putting 7mm under the ballstud on inside camber link mount when installing the CF hubs.
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
yeah, I didnt realize I needed the 12mm ball studs for the 8mm mod....and I already placed my order for parts, woot
That is fine, I am just getting really frustrated with this team edition 4x4. It came lacking in so many areas, I find myself constantly ordering parts. I ordered the C hubs and now I find out once my parts come in, I cant set it up properly. Meh. lol, I just want the truck to drive in a straight line and its costing me so much to fix all the issues.
Mine drives just fine in a straight line, and the 8mm mod isn't mandatory. It all depends on your ability.
The stock setup I've been using has been decent, but I moded the hubs anyway to try something new. Figure out what works for me. There's one "cookie-cutter" setup that works for everybody, or everywhere for that matter.
I hope that clears everything up.
lol, my truck drives far from straight. lol, it needs constant correction, because of the sensitivity issues in the steering.
So add weight in the front near the servo?
how well do the 12mm HD stud hold up with 7mm under them? do they bent alot? Should I order a gaggle of them? I might be able to cancel and fix my order if I do it soon. Once it packed, I am SOL, lol.
Also, you can add a few shims to the ball stud that you have to raise it some for the 8mm mod. It doesnt HAVE to be 7 or 8, could be 5 with the stock stud
I am currently running 5mm with the stock hubs. if I raise the outside 8mm and dont raise the inside, what will the net effect be?
You are changing the diameter and pitch proportionately. All that really matters is the wire length, or how many free coils there are. I said "technically" because you are slightly cold hardening the spring, but since these springs are cold rolled and coiled, it really doesn't matter. The spring rate doesn't change.
