SC10 4x4 Thread
How do you guys like the EXOTEK LCG does it make a huge difference in handling of the truck?
Indoor track med traction I'm running 30 weight oil in the shocks blue sawaybars front and rear and out shock monts on arms and on tower I'm in be 3rd hole front the same I'm running between 18 to 21 sec lap times when every one else is running 17 and even 16 lap times
Here's the thing with the sc10 4x4, it takes time to get it dialed in just right but trust me when you do IMO its the best 4x4 sct out there. Most people give up on it because they get impatient, but for me dialing/tweaking the sc10 is the fun part. You have to remember the sc10 is one of the lightest 4x4's out there, the only belt driven, and has the best steering of all sct's..... Take your time with it, try different things (diff weight shock oils, diff oil's, swaybars, springs, etc) until you find out what works best for you and your driving style.........
Should not need weight in the back, the design of the truck and motor placement puts plenty of weight at the back. Stick pack users usualy add lead to the front left.
Saddle users usually dont need to add lead, but I have seen a couple people post that they do... in the front.
LOL it took me months with the original sc10 4x4 kit that came out, but I was able to get it dialed in and dropped my lap times 2-3 seconds once I did and I was running stick packs with added weight etc....... Now with my FT SC10 I am still dialing it in, I am now running saddle packs and the exotek chassis so I still need to do some tweaking here and there and I will hopefully have it good to go within the next couple of weeks since I have it off lol.....
(you'll get every side imaginable and be able to make your decision. We've talked about the thing 'too' much already)
Drove the 8mm mod and some other tweaks... Holy crap. I can't make heads or tails of my truck anymore. It's a rocket and rips the corners... but then I'll get into a groove and then the ass goes apeshit and spins all over the place which 'feels' random but I only drove 2 packs so far, so I'm going to keep driving it.
The 8mm and the oil/camber change was intensely different. I got a spark.
I only compare my lap times to... my lap times. Corner speed is a real pain in the butt, it has eluded me for years. If you want to go faster get more corner speed and don't land on your lid. I am no where near the point where 10ths matter, I need like 5 seconds per lap.
I wonder how long until someone makes a part to replace the "8mm mod". Since a few AE drivers are doing it, I assume they will release a part, but maybe not. I am horrible with a drill, I would mess it up.
There's nothing to drill other than making pre-drilled holes a tad larger. It is nearly impossible to screw this up.
Yeah coner speed is really hard and the track I run at has a lot of them losi trucks seem to slide and my truck just likes to roll over on its lid I have hard time getting it to get the truck to clear jumps and the track only has one table top in the track but cannt even get close to get over it . When every one else is clearing it . Tracks really short and not a lot of traction
Hmm, you have no confidence in my abilities, lol. I can burn water when i cook. But seriously, I am on a serious budget. Damn wife wants to buy a house, silly woman. And I would really really like to fix the critical items first. I have a vts...... but no one told me i needed a new gear cover... so fail. I don't have any saddle packs, so that is out for a while. And lol, at getting the alum chassis any time soon. Right now, my main focus is trying to push the truck hard and not blow up my 540, lol.
I am running this setup. Mostly because it uses a stick pack and was pretty close to mine anyway. http://teamassociated.com/pdf/cars_a..._JC_Spring.pdf
