SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Should the shim go between the spacer and the bearing, or between the spacer and the thrust washer? Or does it matter.
The V2 should have come with a machined spacer that goes on the shaft first. If something happened to that then the thrust washer would drag on the transmission housing. Could cause the drag you are describing. That is why I suggested testing with a couple of extra shims. If that fixes the issue then I would contact RCShox for another spacer.
Dammm..I have zero motivation to finish building my FT..
![crying](https://www.rctech.net/forum/classic_images/smilies/bawling.gif)
Don 't even try until you have the new diff shims ....![Batman](https://www.rctech.net/forum/classic_images/smilies/batman.gif)
Will be building one for myself next week ....
and
not really that much of a "tuff guy" ,I just punch it ....
Coyote , hope your blessed & around to make that post as well ....
and
![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
i notice inconsistent slipper fade. sometimes it seems to be working right and others it seems to be not working so good.
i plan on getting the exotec front slipper hub.
i can only say this tho, after reading all the info on here ive only gone forward with my truck. i also have to give "the jang" some credit for his base line set up on his videos.
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
I doubt I'll be here in 25 years..it'd be nice but I'm not counting on it..
I'm going to live forever!
