SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Does anyone run the Tekin Pro 4 motor with the LRP SXX V2 speed control? How's the performance? Are you better off with one of the Reedy 550 motors with the LRP speed control or does the 4 pole perform well with it?
I would prefer to use the RX8 to run the Pro 4, but with the saddle pack config of the factory team truck, I'm not a big fan of having to chop up to RX8 to fit it in...
Any advice would be appreciated! Thanks!
R/C Tech Elite Member
So with the RX8 mounted on the reciever side, do you put weight on the other side with the reciever to balance it out? Also, where do you mount the antenna for your reciever when you put it on the "passenger side"? Any chance you have a picture of this setup?
Thanks!
Thanks!
I was thinking about trying the Exotek locked front clutch. I saw a few posts about it back on pp. 1603-1604, but I'm not sure I've seen much since. I recognize many/most might simply prefer V2 Cdiff. Notwithstanding, I'd still like to hear, so . . .
Can people who have given it a try follow up with additional comments either good/bad? TIA for any additional feedback.
This is the only picture I have for now, I haven't added weights yet because I just installed my rx8 a couple of days ago and haven't weighed it yet on my scales to see where I would need to add them if so. I also have the rx wire zip-tied to the chassis brace just for now because I was trying to clean up the wires a little, however I may just stuff it in the rx box since I put that on the other side and mounted it with double sided tape.......
![](http://img.photobucket.com/albums/v682/ilanstylz/SAM_0175.jpg)
I'll try and take closer pics later on and post them if you'd like.
Gentlemen,
I stripped out a set screw in my factory team aluminum wheel hexes. Anybody have a good method on getting that out?
Thanks for the help!
C4 lol
The hex is pretty much done unless you can find something to take the screw out with, torx, extractor, flathed, Allen wrench jb-welded in, etc.
Otherwise just cut a slot in the head of the screw with a dremel
Pluses:
-More drive out of the corner. Noticably more. You can really see the front wheels ripping now for traction.
- Easier to correct in the air. I assume because the front wheels are pulling in the air all the time
- Truck is not as twitchy and assuming you have the rear locked in you can push harder out of corners.
Delta's
- Off power steering is reduced slightly. running 30k in the front now and 10k might now be the ticket
- Too much power off a jump can send the nose sky high.
We like it outdoor at least.
We ran one of our trucks without it and with it, back to back, on the same day at the same track.
Pluses:
Delta's
Pluses:
Delta's
Did you happen to notice additional wear on the tranny? Did you change how much you tightened the VTS slipper nut?
Thanks for the reply. I am still learning to drive this thing and want to go step-by-step. I still wanna try the HT slipper on the inside, this Exotek mod, garodiscs, possibly Cdiff.
Jeff
Would someone please wake me up when this thread stops talking about suspension bind being related to camber links, lol. To those of us still trying to learn setup and what adjustments do and why, this bind thing is really confusing the $#@& out of me.
When you hear "bind" think resistance to movement. Or lack of resistance.
But that makes me think softer suspension. but less bind = less traction?
less bind makes less grip , but is smoother on bumps ...
Jeff , "resistance" sounds good to me ....
Okay,
So less bind = a softer suspension over bumps but yields less traction in the turns.
