SC10 4x4 Thread
Springs
Stick with the spring that performs best for you .
We are using slicks at the moment @TRCR and even with the grip slicks bring I had better traction with the standard yellow spring .
Sometimes the truck would step out of the turn just a little and add time to the lap using white ft.
Also the roll was way less with the white ft, good for the sweeper & higher speed turns , but bad for sharp turns on the infield as you get a bit less steering .
If I were you ?
Try the yellows again & compare the times .
That's what I did and discovered the spring that was faster for me ...
If I were you ?
I had the NON-ft setup, I am now rebuilding with the Exotek,
Saddles, & most FT upgrades....
So, with the extra weight, some people were saying that, instead
of White F, in the rear, they were going with(I thought green?)
Maybe it was blue or yellow?
THX
Is 91122 FT Hard Anodized Bushing, the upgrade for
# 91028(steel hat bushing) ??
I am putting the optional steering rack in and realized I
need 6mm ballstud...(my OG kit has 8mm in there)
So is the upgrade the FT tin Ballstuds & FT H A Bushings??
THX, need more parts
@jpure: You can do what I did.. sand down the 8mm ballstud a bit and it will fit fine.
I didnt do anything with the 8mm studs and it works fine for me.
so to summarize, I need less then 8MM,
- 6MM OR Sand down a MM or so.?.
I was thinking about upgrading to the FT tin B.studs? worth it?
was just about to hit up AMAIN..
-6mm FT tin BtudsS
-10mm FT tin B.studs(for 8mm mod)
**What about the bushings, is that the upgraded bushings??
91122 FT Hard Anodized Bushing, worth it?
--In the process of FT rebuild now
THX
Go with a 12mm stud for the 8mm mod, or you will not be able to fit more than ~5mm of spacers.
I didn't sand down 2mm, just a little bit.. maybe 1mm or so.
I actually hate my SC10....so to me spending ANY money on it is a waist of money..and the worst part is I'm committed to getting this SC to work..
oasis
Don't quit , don't give up ...
Just get back in there and get her done......
OK,
-6mm FT tin BtudsS
THX
-6mm FT tin BtudsS
THX
@coyoteslash: you can add this to the motors:
Tenshock sc401 4600kV:
Fits perfectly, comes with holes for m3 and m4 screw, i would recommend a 32dp pinion beetween 11 and 15 (depends on your local track) with 5mm hole.
i def would do that, I really liked the white, BUT
THX
THX
