SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
no but i make them for the SCTE too.
ALrighty, got my 12mm studs and i am about to machine some spacers and do some more tuning on thursday! i still dont think its going to work for me but ya never know!
Try 8mm right above the center hole on the hub. Was dialed on our outdoor track. 5mm on the inside hole but I did not have the longer studs to use last weekend.
R/C Tech Elite Member
![](http://www.weebly.com/uploads/3/0/4/3/3043342/945937.jpg?9889287)
Fun video done by a club member from last weeks out door racing. Check out 1:34. Two SC10 4x4 going around the high speed sweeper at the end of the straight. See if you can tell which yellow truck had the center diff in it. ![Batman](https://www.rctech.net/forum/classic_images/smilies/batman.gif)
Also the Hooters truck makes it in a few shots.![Cool](https://www.rctech.net/forum/classic_images/smilies/cool.gif)
+ YouTube Video | |
+ YouTube Video | |
Very nice looking track
I read this after i already set it up but i am going with 6mm on the inside +8 on the outside inner hole and 5mm inside on the front. track will be med grip/dusty and bumpy.
![Questions??](https://www.rctech.net/forum/images/icons/icon15.gif)
Track today truck was feeling Great!!!
-followed Ryan Mayfields '11 slick polished groove setup,
almost to a tee...
Few Qs.....
I have the RC SHOX Garodiscs that i had from 5months ago...
I have the non-basket right now & the Slipper & Garodisc
are working soo good, I'm considering not upgrading to
AE VTS slipper upgrade, any thoughts???
I know the upgrade is because all the probs every1 was having....
ALSO, why did RC SHOX change the Garodiscs for the regular
SC104x slipper(Holes look different)????
I am going to order more for the reg&VTS slipper, luv them!!
almost to a tee...
Few Qs.....
almost to a tee...
Few Qs.....
almost to a tee...
Few Qs.....
I am always changing and trying new things, the holes dont really do much of anything unless there are ALOT of them.
If you want to upgrade anything move up to the center dif!
2nd Q.....
Ran about 5packs today & when i got home,
noticed the front Left shock is about 1/4 short of
full oil.....Noticed my a-arm was covered with oil....
Q...
I am going to order the Trackstar o-rings & shock snot,
Is this my best cure & How many do I put in each shock?
etc:
2 TS o-rings??
1TS o-ring & 1stock x-ring????
1 TS o-ring bottom??
WHICH????
THX
Q...
etc:
2 TS o-rings??
WHICH????
THX
Was hoping u would answer, i been out the game since November,
So just getting, back Born again noob....lol
1st run with SC104x in awhile, & i was very happY!!!
I have the FT upgrade kit on the way....
I might just try the basket, can i use the pads(from u),
on the FT basket, or do i need the ones made for it?
Can i use the ones i have & the ones made for it???
I was going to prolly order both anyways...
Jay
I'd like to share my setup,
any1 tell me how, it's in PDF form now, from
blank AE setup sheets, that i filled in.
By the way, ran white front springs on rear...
Worked fantastic, stick pack setup..
(Slick polished groove)-Tight indoor track
Want to share setup...
J
J
+ YouTube Video | |
I sincerely hope you don't consider that a blown out track lol...looks more grooved up them some of our indoor tracks here...
![EEK!](https://www.rctech.net/forum/classic_images/smilies/eek.gif)
+ YouTube Video | |
