SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Trcr added new clay about 4 months back ...
For the first 3 to 4 weeks the clay is not near as abrasive as before ...
For Right now ?
JConcepts pressure points are your best as the track is still fresh .
Once the track drys out the rattlers & bar codes would a better choice as they can wear longer ...
I have 1 rear shock that continues to leak. I have replaced both x rings, used green slime, new gray and black bottom caps. Any ideas?
I had the same issue as well. Back right shock. I rebuilt all 4 shocks with new Trackstar o-rings. Made sure that the insert was facing the right way, tightened the bottom cap as far as I could on all 4......back right leaked like a screen door on a submarine. Replaced the 2 o-rings with another completely new set, and it seems to be OK now. I'm wondering if I buggered both of the o-rings on that one shock when I inserted the shaft....
I have the same issue, both rear shocks leak for me.. used green slime, trackstar o-rings, stock o-rings, tightened down as much as possible, tightened down just hand-tight, etc.. no change, always leaking.
I use green slime with track star o ring on the top and AE x ring on the bottom. I had intermittent leaks with all track star so I met half way.
Still less stiction than all AE rings but with no leaks.
Why are ppl using front blue springs on rear?
The rear spring rate is too soft, relative to the front, especially IF you are running yellow fronts. Some users don't like the change, but most have been positive
Cameron started running greens fronts in the rear, and then switched to whites fronts on the rear. I ran my truck with his setup indoor and it was the best my truck has ever been.
So does' any one run Red rear (3.4) and green fronts (3.5)?
You COULD always get a set of front springs near blue but not blue. That way, even if you don't like them in the back, you can still use them as a tuning option on the front.
I have a full set of tuning springs, both front and back, and I can tell you that I much prefer the fronts both front and back.
![Stick Out Tongue](https://www.rctech.net/forum/classic_images/smilies/tongue.gif)
But it's only a couple bucks for another front blue set and if I don't like it, it will not be the most expensive error I've made in rc
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
