SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
get the 2 ways for sure. what springs/oil u running? center diff? exotek? saddles?
Yellow, Front blue 35, 30 Yes 10k,5k No Yes
just got my up grade kit in took some work.
Hi recently I took apart the slipper clutch to put in the 19 tooth rear pulley. I did that succesfuly. However very time I even put on the tiniest bit of throttle the slipper pads fall off and stuff up the drive. Do you even need the slipper pads and if you do how do you get them on properly?
It is very loose and gets tossed around by the bumps.
I have a regular balance lead for a stick battery...each battery has a positive and negative with no balance port...so for the balance leads do I run them into the + - that the jumper wire is also ran into?
I just finished my ft kit.... I'm have a reedy sonic 550 4.5...the spur is a 62...any suggestions on a pinion...our new track was done today..it looks very long with big banked corners...I've heard anywhere between 24 and 12...that's a big range!!
Is there advantage to running STRC pulley?
![](http://i655.photobucket.com/albums/uu273/ancona/DSCN1315.jpg)
so when my antenna ripped out last week and was causing my car to cut out i bought a new reciever...the same one that was already in the car (TRS401ss 4ch reciever) i hooked everything up and when i turn my car on i hear everything start up, but when i turn on my remote nothing happens, no beeping noises or anything. is there some way that this new reciever needs to be synched to the remote or what do i need to do to get this running again?
![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
Alternatively, get the RCShox Garodiscs. Mine fit SO perfectly into my spur gear that they essentially snapped into place and WILL not fall out...even when tapping on the backside of the spur.
