SC10 4x4 Thread
I have the reedy saddle pack #627... stupid question here....do these get charged individually?
Not sure if they can be charged separately. I would assume so. But verify that first.
I run primarily on outdoor tracks here, I wish I had more indoor.
Yea you always want to run packs as a single unit when using and balance charging. This way each cell is charged to the same level.
got my ft done sans body. right now it has a havoc pro sc (non x drive) and a viper 5.0 l, strc steering kit along with strc pulleys, rcshox v2 pistons. my next paycheck ill probably get a rx8 esc. i have not tried tekin yet, i had the havoc sitting around.
it was a fun build and thank god my roommate has a cordless power drill. i got my diff dilemma solved, one of the 4x4 guys at the track built a spare gear diff with me so i could see what it should look like and how it should feel when done. after a few runs on street tires on the street, i wound up with a 13 tooth pinion and temping out at 135 after 6 minutes of hard running. should be close for the track this upcoming week.
Well went to my first 1/8 track today.... Didn't go so well. Track was loose and bumpy. Need some 2 stage pistons! Found the truck ran much better without sway bars.
I did not order a balance charge harness....and these have no balance ports...it looks like the reedy harness has 4mm bullets on end of balance leads...do these get plugged into where the jumper wire plugs?
OMG Evil I would love to run that track.
do you have the leads to plug in?
It's a lot looser than it looks. Most run city blocks.
Have any setup suggestions? Doesn't help that I'm not a very good driver but a good setup can't hurt. BTW the A main was all LOSIs
