SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I think this was mentioned before but I can't seem to find it, I am currently building my new ft kit and my rear gear diff locks up when I tighten the screws all the way dwn. I've tried washers and ive tried back the screws out a little bit. Backing the screws out. This seemed to help a bit but when I bolt the rear shock tower to the diff case, it binds again. Any suggestions ? I am using the screw lengths according to the manual. Thanx.
What is the difference with the ft front shock tower? I noticed the upgrade kit comes with a shock tower. thanks
Thanx for your reply. I stopped messing with it for the night because I got frustrated. I'll give it a shot tomorrow, hopefully I can figure it out.
When building my new FT 4X4 SC10 I discovered both deep diff gears were the wrong parts. The deep diff gears were in the bag with the rest of the parts. The problem was the seat for the large O ring on the inside of the diff case was too small. I did not notice the issue when building the diffs up the first time, but once installed there was a lot of binding and they did not feel right. I pulled them back out and opened them up. That is when I saw the very outside edge of the O ring sticking outside of the washer. In the pics I was able to turn the outdrive to give a worst case scenario for the pic. I also show the wrong diff on the left and the correct one on the right. I must say AE support is great. I called them and they sent out the new diff cases right away. I got them 2 days after I placed the call. Once I had the new parts, I took the pic showing the correct and incorrect parts before I sent them back to AE. I'm posting this in case there are other wrong diff cases in some kits.
Bah, since I'm new, I don't have enough posts to show pics.
Anyway, if you are having diff issues, this is something to look at.
http://www.teamassociated.com/parts/details/91174/
Includes all the parts below:
Belt Cover
Rear Shock Tower
Optional Steering Rack
4x4 Chassis Brace Conversion
4x4 Saddle Pack Battery Strap
VTS Slipper Conversion
4x4 Saddle Pack Cradle
there is a post some where in the past that talks about the rear tower beefed up to deal with the chassis brace
[QUOTE=Eradicator;10569737] That is when I saw the very outside edge of the O ring sticking outside of the washer.
So you could see the o-ring sticking outside the washer that's under the sun gear while the outdrive was still installed? That washer is like twice the size of the o-ring. I'm just trying to picture this as I've had mine apart a couple of times trying to make them a bit smoother. The last time I opened them I didn't take off the outdrives and didn't see anything out of the ordinary...
No they don't, I had to drill some new holes on my exotek chassis. I believe the one coming out is gonna have the holes predrilled.
Anyone else have the problem that the team kit (not FT) shocks are constantly leaking from the bottom? I rebuilt them lots of times, replaced the seals with the trackstar o-rings, used lots of green slime, etc.. this truck has been on the track only for two days, so it's not any kind of wear, and the leaking happened even before it was driven at all. Also, I could be mistaken, but it looks almost like they leak from around the black bottom cap, not out of the shaft holes.. but it might just spread around and appear that way. They even leak slightly when sitting on my car stand with the wheels off the ground.
I'm far from being a machinist, so the thought of drilling perfectly aligned, counter sunk screw holes into a brand new $100 aluminum chassis causes anxiety!
![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
You may have stripped or cross threaded the cartridge also, just something to check.
getteing my up grade kit to day in the mail
![Batman](https://www.rctech.net/forum/classic_images/smilies/batman.gif)
