Like Tree5Likes
SC10 4x4 Thread
Old 05-24-2011, 07:45 AM
  #2026
Originally Posted by mxnickj
does anybody know if there are any plans on a stainless steel screw kits in the near future? I gave my baby its first bath over the weekend and the screws are all rusty and nasty looking now. I forgot how much better things looks with all the silver stainless screws in place of the black/rusty ones
RC Screwz.
CraigV is offline
Old 05-24-2011, 07:54 AM
  #2027
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
seems someone could make some money offering some swaybars while the AE stuff is still not available ...
Cain is offline
Old 05-24-2011, 08:01 AM
  #2028
Front page has been updated:
  • More gearing suggestions added
  • How to measure ride height
  • Stopping dirt from getting into spur/pinion gear
CraigV is offline
Old 05-24-2011, 08:03 AM
  #2029
Trader Rating: 14 (94%+)
not worth the time, once you get them done and inform everyone they will be available from AE, then you will have wasted your time. good idea
but to short lived to be worth it.
Team T2C is offline
Old 05-24-2011, 08:04 AM
  #2030
Aoh
Trader Rating: 16 (94%+)
Originally Posted by rednck21
anyone broken a CVA pin yet? i did in the the main on saturday, running in 2nd place...
i did, on the outside joint on the hub, it looked like it shattered/cracked, might be a bit too brittle?
Aoh is offline
Old 05-24-2011, 08:21 AM
  #2031
Trader Rating: 18 (100%+)
Default Havoc pro sc system
Anyone use the Novak pro sc ballistic 4.5 system in their sc10 4 x 4 yet. Just wanted to know if they fixed the esc yet or is it still fire prone as suggested on various posts. Would the gtb 2 package be any better. Or should I skip Novak esc's all together.
You opinions would be valued
Thanks lyrragnus
lyrragnus is offline
Old 05-24-2011, 08:22 AM
  #2032
Racecrafter's Avatar
Trader Rating: 25 (96%+)
I was afraid we would see this eventually.
Track Star build. Quote;
" The CVAs went together really quick and as a side note with as beefy as the rest of the truck is and using 32 pitch gears for the use of 550 motors I found it strange that they chose to stay with the miniscule 1.6mm drive pin for the CVA joints. On top of this only one set of holes are included in the axles where 2 to 3 more pair could have been added to prolong the use of them."
Racecrafter is offline
Old 05-24-2011, 08:39 AM
  #2033
MistermomHB's Avatar
Default sway bars SC104x4
Originally Posted by jammintosc104x4
I see all over the forms people asking about the sway bars. They help I race at a high traction clay track. The set up with sway bars is working for me, after a week of tuning. Ok the setup that works for me "now" (time is the only constant.) 10,000w front diff and 40w front shocks, 3k rear diff 37.5 rear shocks, the sway bars mounted no mods from my jammin. front sway 1.5mm rear is 2mm. I hope this helps someone...
Sportsman 4x4 SC WCRC
JamminToSC104x4 and lovin it.
Originally Posted by Gabriel2010
Did anyone find out how to build the sway bars ? What rod to use ?
this is the sway bar kit for he jammin no mods... post #1950
MistermomHB is offline
Old 05-24-2011, 08:40 AM
  #2034
t4mania's Avatar
Anyone have any trouble getting the 4mm locknut on the steering servo saver. Can't seem to get the spring compressed far enough to get the locknut started.
t4mania is offline
Old 05-24-2011, 08:42 AM
  #2035
t4mania's Avatar
Thanks lyrragnus
I went with the Tekin RX8 esc. Much more reliable & easy to setup. Just my .02 cents.. Plus its a 1/8 scale esc so it should run alot cooler..
t4mania is offline
  #2036
Jim Hustins's Avatar
Thanks lyrragnus
My friend and are both using the combo. We both love it. Fast and smooth.
Jim Hustins is offline
Old 05-24-2011, 08:46 AM
  #2037
+1
Old 05-24-2011, 08:49 AM
  #2038
Ya, it was a bitch. You just have to push really hard. I found the easiest way was to hold the nut driver and nut in my left hand (i'm right-handed), and turn the whole unit with my right hand.
Just seemed easier that way for me.
CraigV is offline
Old 05-24-2011, 09:18 AM
  #2039
CentralCoaster's Avatar
Originally Posted by T-BirdJunkie
Krome, ThunderbirdJunkie has the same motor. Only problem is he washed it using hot water
What servo/specs? and have you had any BEC shutdowns with the mamba max?
CentralCoaster is offline
Old 05-24-2011, 09:25 AM
  #2040
Originally Posted by Vegatron75
Do any of you guys think that the stock settings for the servo saver are way to tight?
FYI, If your radio doesn't have EPA adjustment, you'll have to get a radio that does. I had been making the traxxas link radio work up until I got this truck, ended up stripping the servo horn. I've since bought a airtronics radio.
I could not get the servo saver to budge by hand, but that was pre-lubing it. I'm running 70% EPA. Another option for cheap radio guys may be trying the slightly shorter 2wd horn, with ball stud the other direction. I noticed the "A" airtronics servo horn has sloppy splines and strips out easier than it should. Get some spares if you run this horn and hold out for a better quality one.
Yeah seriously.. they need to redesign that part with some more threads on it. Or put a little softer spring on.
