SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Ya know I had a bnib Hitec 7955 that I was gonna use for a ebuggy but I sold it, something told me I should have put that sucka in. FAIL
I don't have another servo unfortunately.
Yes it is a giant p.i.t.a to swap one out, I only want to swap out only if I absolutely have to.
The weird thing about this is it is intermittent and usually happens later on in the day when I'm running.
I'm wondering this: If my batteries (saddles) are discharged to a certain degree that they can't maintain the amps.
I am using 20c saddles, that could possibly be it. Maybe I need more c ?
ok cool, sorta confirms my thinking. My batteries would be warm after running them. I'm only geared at 13/62 but I'm sure the amp draw is working these suckas hard.
I'm going to try the turnigy nano techs that are advertised as 65c. I doubt they are really 65 but I'm sure they are more than 25 c.![Smiling](https://www.rctech.net/forum/classic_images/smilies/kawaii.gif)
What all saddle packs are you guys running? I'm not at the point where I can afford Reedy saddles.
![Frown](https://www.rctech.net/forum/classic_images/smilies/frown.gif)
I just got a Tekin pro 4600/rx8 what was wondering what esc settings guys are using for it. Also what pinions would be a good starting point. Thanks.
Don't forget to take your receiver apart and clean the dirt out of it every now and then. I have had my truck act like it was getting radio hits, shut downs, and other problems and it was all because of dirt in the receiver.
I also found without a cap (Savox) that turning the wheels back an forth on the bench I could get the receiver light to go out and it would go dead for a few seconds.
Good catch Cameron I'm gonna take a looksie tonight.
Remember back in the day when we put them in baggies? (or at least I did)
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
Being high voltage I guess you could power the servo right off the battery and bypass the BEC as well, but I would be concerned with how the handling would feel as the servo would respond diffrently as the voltage starts to drop.
What all saddle packs are you guys running? I'm not at the point where I can afford Reedy saddles.![Frown](https://www.rctech.net/forum/classic_images/smilies/frown.gif)
I got some of the 90c Orions on the way. Only place I could find them was on ebay and I didn't notice they were being shipped out of hong kong. For the $5 I paid in shipping I don't expect to see them anytime soon.
How often do you change diff fluid?
Thanks, I have been changing every 2 race days so far.
Mine don't leak anymore. I started putting a thin bead of 100% silcone calk around the seals and haven't lost a drop of fluid since. I haven't replaced the fluid since I last did that, so we'll see how re-usable the seals are after I do that sometime this week.
Settings I had mine at:
No current limiter
Brakes 80perc.
No push or drag
Timing at 5
I run on a tight indoor small track...
