Like Tree5Likes
SC10 4x4 Thread
Old 03-16-2012, 11:20 AM
  #19351
Theres really no c rating standard, so with that being said im going to be selling 1000c rated batterys soon lol im only gonna charge u guys 200 dollers a pack
rickybobbyxxx is offline
Old 03-16-2012, 12:12 PM
  #19352
vito's Avatar
theres a new hobby shop here in town now he is getteig set up now and can hook up my esc and motor. i found the place to day thanks guys for the help. its the stock from the old shop and they are no more. and he just starting out .
vito is offline
Old 03-16-2012, 02:18 PM
  #19353
fq06's Avatar
Originally Posted by Cain
thanks. main thing I was looking for was to run shorter wire setups.
Too bad they don't make a version with tabs you can solder to.
If I remember correctly, ck said that you can cut and shorten them. Check with Mike, but I think they just need to be equal length so you don't affect timing.
fq06 is offline
Old 03-16-2012, 02:29 PM
  #19354
vito's Avatar
just got all the stuff to get my truck done thank you guys
vito is offline
Old 03-16-2012, 03:08 PM
  #19355
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
Tower is showing the Factory Team kits in stock now
SOuthernFRIED is offline
Old 03-16-2012, 03:19 PM
  #19356
Default c rating
i see everyone with your crazy c rating. well if your run a 4.5 550 you can get a way with just 35c.(if you try much lower c you taps will taps will get to hot)40c should be a perfect fit. for the rest of you with you 90c even if it did some how give you more punch (it should not/iam not sure but if i was to guess 50c would be the max power you can get that you motor can take+many battery lie on the c rating) what the point where on dirt!!!!
let do some math the lower your volts the more amps your going to run. so let say you at the end of your run 6.5volt and you run a SC4X 4.5(550) witch is 900watts your amps would 138.46/// let use the Carbon Pro 90c 2s 5000mah this how you do the math 90x5000=450000/1000=450amps(that continuous amps not even max). so why do you get a battery 450amps wend all you need is 138.46amps. a 35c 5000 is 175amps. i had a 20c 4500 that melt the tabs witch is 90amps far to little.
plz tell me if i am wrong!!! with my numbers.
gatorage is offline
Old 03-16-2012, 03:31 PM
  #19357
vito's Avatar
i hope the new parts are soon to come out now
vito is offline
Old 03-16-2012, 04:51 PM
  #19358
vito's Avatar
ill have my truck done by the end of the mo thank you all for the help
vito is offline
Old 03-16-2012, 06:43 PM
  #19359
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
Ok roll call, who's gonna run their truck tomorrow?
JEFFs SC10 is offline
  #19360
Evil Genius jr.'s Avatar
Trader Rating: 28 (100%+)
Me!!
First run with center diff and blue on rear.
Evil Genius jr. is offline
Old 03-16-2012, 06:55 PM
  #19361
MantisWorx's Avatar
Trader Rating: 28 (97%+)
ME!!! reverse aluminum idler gear and B4.3's
MantisWorx is offline
Old 03-16-2012, 07:00 PM
  #19362
vito's Avatar
i was in town to day a saw some rcs in a store front. it was a new guy in town and is getteing set up. what a nice fined today
vito is offline
Old 03-16-2012, 07:01 PM
  #19363
ilanstylz's Avatar
Trader Rating: 142 (100%+)
Wish I was, I'll be down for awhile til my new esc and motor come in...
ilanstylz is offline
Old 03-16-2012, 07:02 PM
  #19364
vito's Avatar
thanks guys for the help got a big box of parts to make it move now.
vito is offline
Old 03-16-2012, 07:06 PM
  #19365
King DORK's Avatar
Trader Rating: 53 (100%+)
I called them today when I saw that since I've had one on backorder since Feb 1st. They are listed as "in stock, limited quantities" however the stock that they received came in in their Reno warehouse and is only for filling backorders. The next shipment will be the same and so on until all the backorders are fulfilled. The likeliness of them actually having stock on hand to purchase will probably be highly unlikely for quite some time. I always call and get on them when I have something on backorder and it shows "in stock"
King DORK is offline
