SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I have a 4x4 ordered that I am gonna install a MMP and Tekin Pro4 4000 into. Looking for starting gearing and what pinions and/or spurs I should keep on hand. Thanks for any help.
I'm considering the Tenshock 411 4000kv and a Hobbywing ESC. What do you think of this combo? Anyone running it? I have read the entire thread, but don't recall if this exact combo was being run. Didn't come up in a search.
Also, suggestion on one of the following Hobbywing ESC's?
I think this is the one Mantis was running.
http://www.hobbywing.com/product_show.asp?id=248
or
http://www.hobbywing.com/product_show.asp?id=263
or
the XERUN v2.1 120A is the best esc of hobbywing.
or
or
I come off at 160F after 8min main.
If you run less timing you can run 62/16.
I suggest you run a Castle BEC to avoid brown outs on the MMP or go with the Tekin RX8.
Are you running a fan on your motor, and what type of track do you race on (small,medium etc)? I have the same motor and highest I've gone was 15 on the timing with the same gearing.........
Hey guys, there was some talk awhile back about putting shims under the sun gears in the diffs to tighten them up.
I never saw an exact size of those shims... Does anyone know what size they are?
thanks
thanks
When I say "on/off" switch I was speaking of the way that 4 pole motor just snaps right down when off the throttle. I thought I had drag or drag brake set at first. The magnets are so strong that the things just wants to lock soon as I get off the throttle. It can be overcome by staying slightly into the throttle most times when with the tekin pro4 4000 I can't actually hit neutral instead around a turn. I still think its a great motor.... Check out my sig tag, I'm running it.
Sal
Sal
I could push it harder, but it has all the torque and speed I can make use of.
Sal
Sal
Sounds like a Tx Esc calibration issue
ordered my saddles from Gens Ace, they had them shipped within an hour or tow it seems.
I checked the tracking and even though I specified ground, they already made it from California to Jax, Fl already.
The estimated delivery date is next week which means they are sitting in a warehouse.
It would be sweet if I get them tomorrow. I could possibly test Saturday and go racing Sunday.
![Cool](https://www.rctech.net/forum/classic_images/smilies/cool.gif)
![EEK!](https://www.rctech.net/forum/classic_images/smilies/eek.gif)
![Mad](https://www.rctech.net/forum/classic_images/smilies/mad.gif)
I ordered mine Monday and they haven't even shipped yet ![flaming mad](https://www.rctech.net/forum/classic_images/smilies/angryfire.gif)
Oh and the 1410 pretty much is an on off switch.
