SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
what makes the center diff adjustable now? and what are you adjusting?
Is mine gonna be adjustable?
![Confused](https://www.rctech.net/forum/classic_images/smilies/confused.gif)
I agree, i like the 3-3 block ALOT right now. only thing i dont like is that it does stiffen the rear up a bit and on rough tracks its a bit of a handfull.
On that note, my adjustable center dif is a go! the acceleration is astounding! I now have one part of the big jump problem solved as I over jumped the triples and quads by a LONGSHOT, same with the quads but i couldnt land them because the nose wouldnt come down![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
I will have the idler gear proto done in time for testing this weekend.
How he's going to do it? I guess we'll see!
Hey guys. Had my very first club race last night in the beginners 4wd SC class. 2 qualifiers and I was able to make into the A-main in 4th position. In the main there was carnage into the fist turn and I was able to get around and take the lead. That was short live and after several crashes I was dropped to 2nd then 3rd position and finished the race in 4th. The 3 podium finishers were all sLosi. Oh well not bad for a first race. I will say that my truck running the Exotech chassis, saddle packs, RCShox ACKbar and center diff was running top notch and easily kept pace with the sLosi. If it wasn't for me pushing too hard and making mistakes I think I could have at least gotten back to 3rd. My RCTECH version original FT SC10 4x4 is gonna be kickin' a$$!
iIhave seen Marcus' new center diff design, and it is pretty brilliant. I dont know how in the heck he thought of it, but it is a never before seen design.
I just saw that the manual recommends that when the belt tension is right, if you push in the middle of the belt, it should at most give by 3mm. Mine gives easily to the center divider. I tightened the front tensioner from the recommended 1 position to 3, and it made little difference. Is that normal and the manual is wrong, or is my belt too long?
Just to make sure, you said you went from 1 to 3 and it made little difference ... was that for both front and rear pulleys? Are you running the 20 or 19 tooth pulley? Did it get tighter or looser at all? The 1 position is the lowest in relation to pulley center-line and should make the belt the tightest. I personally would not run it there. I have mine running in the 4 position front and rear and have had no issues with it skipping nor flipping since I installed my chassis brace. Prior to the chassis brace it would skip under high speed braking which, considering the amount of flex, is what should be expected. I have never had a belt flip but that is something a few others have run into on this thread.
As for the 3mm of flex, that is completely subjective IMO. Who is to say that you and I push with the same amount of force. With my pulleys set at 4's I am able to touch the belt to the center divider with what I consider to be minimal force which in my experience that is not a bad thing at all.
Arakon,
Too many variables just fussing with the belt.
Trader Rating: 77 (100%+)
Where is this center diff for sale at?
I did the math , but still not for sure ...
I believe Scott won the Sc4x4 class though, O man !
Any body else have a clue ?
Was at the local track Friday night and Fast Lap Products was testing a new front slipper hub. Looks interesting.I talked to Billy and he has been testing this for about 6-10 weeks . Final version is done.
Individual ft & back slippers ?
Now that is brilliant.....
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
