SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Question...i have a clutch basket and Garodisc. If I make the move to center diff will I notice a difference? I run on a clay track. Just want to make sure it worth the money. Anyone?
Trader Rating: 77 (100%+)
http://www.rctech.net/forum/track-lo...ard-track.html
Let me know what you guys think.
I havent personally gotten one yet, I keep running into money problems... But, from what I have been hearing, It's a night and day difference.
Does anyone know if the bleed screws in the shock caps are the same size as the ones that hold the piston onto the shock shaft? I managed to drop one of my piston screws, and I cant find it and need something to get me by.
I like them for the street and mixed driving, but I prefer the proline badlands for any kind of off road bashing.
are the ft wheel hexs a must have ?
http://www.amainhobbies.com/product_...um-Wheel-Hexes
The FT hexes have a set-screw that holds the hexes on, AND they won't deform if you tighten the screw down really tight. I am quite happy with my purchase of these. Much happier than my purchase of the FT pads, and they're pretty much the same price....
A few weeks ago, I had a rear wheel hex, round out and ran the stockers in the rear with my caliber in the front. Didint feel to bad either. Had the pull from the front end and the rear would slide around perfectly with enought bite to get the truck going nice and fast.
You know you can use nail polish remover (acetone) to remove the tires from the rim and try gluing again? You just need some Simple Green to make the tires soft again before you reglue them. You can use this method to reuse rims after the tires are worn out too.
![](http://i655.photobucket.com/albums/uu273/ancona/005.jpg)
![](http://i655.photobucket.com/albums/uu273/ancona/004.jpg)
