SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I had 60K in the front and thought it was way better than the 30K I have in it now, but some users reported breaking front driveline parts as a result of too little diff action.
Ever driven a sedan with a front diff, and then tightened it way up? Or a one way, and then switched to a spool? Same thing as heavier fluid. More steering center in, pushes center off. This is why the Ryan's setup sheet from the Reedy Race/Spectrum race has the front overdriven, it adds on power steering.
But going to go bsck to 7k f and 5k r once I get the rcshox center diff in.
![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
Your correct about the thicker diff oil though , thus why no overdrive ...
10K in ft ...
7k in back
[IMG][IMG]dscn1531.jpg[/IMG][/IMG]
my race rig ready for action
do you have a setup sheet?? and your Belt Tension position? Thanks
ps maybe post some more pictures????
thanks
I am taking my truck apart to refill the diffs and check warped a arms etc, when I noticed this? I am running the basket, with 1 HD pad on the inside and 2 standard pads in the basket. Also the the pads are super slick there is no grip on the pads at all. My slipper nut I am not running flush because it seems if I do the spring is almost all the way cranked down. Any tips?
Here is a link to the pic of the spur gear:
http://s1192.photobucket.com/albums/...Picture051.jpg
ANd if you perfer a drier cv lubricant you can use what I use. Graphite powder.
20K front
3K rear
middle on all four corners tower
Outer front arm
Inner rear arm
Middle rear hub, inner on link
Short link front
3/3 toe/AS block
1.2 pistons..on all 4 corners
35w AE front
30w AE rar
Yellow swaybar front rear
Yellow ssprings front rear
lipo IB5600 50C middle..
hey guys anyone know the weight of the exotek aluminium chassis by itself? just trying to do a weight comparison between that and stock plastic center chassis.
Here are a couple pics of my rebuild using a new kit.
![](http://i28.photobucket.com/albums/c222/dansmock/2012-01-21_13-17-01_746.jpg)
![](http://i28.photobucket.com/albums/c222/dansmock/2012-01-21_13-15-41_898.jpg)
no weight needed to balance. Bias is 45% front 55% rear. 50-50 left to right. Total weight ready to race is 6.45lbs. The carbon fiber eliminates torsional twist. It's extremely hard to traction roll and even when it does you can tell it's going over and let off on the power a touch to settle it back down. I think keeping as much weight on the center line as possible is the key. I think that's why saddle packs in line are working better than side by side. Add a ball diff from Marcus and it's a tough truck to beat
How did you cut the top plate?
