SC10 4x4 Thread
#1486
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I had two that were leaking when I pulled them out of the box. Thought it was just from factory assembly, installed and ran anyway. However, they were leaking. What I noticed was; 1. caps were a little loose 2. bleeder screws were loose (which has no effect running bladders). I then pulled all of them apart and started from scratch and used green slime on the o-rings and made sure caps were tight, but not too tight as to ruin the bladders and put locktite on the piston screws (as two had none and were a little loose). So far, no leaking
#1488
All four of mine were leaking badly - but not from the top as expected. I needed to tighten the grey plastic nut into the blue metal section. You need to use the two wacky wing nut looking wrenches that they supply.
Mine needed some torque on them, did not turn a lot, but enough to tighten them down and keep them from leaking.
#1490
Orion experience 2 pro 3750 kv motor and esc combo. clearanced at stomer hobbies for $99.99. Fantastic in my ae 4x4 indoors and out and probably best combo i have used in my kyosho scr. Insane speeds, butter smooth. You would never guess its not sensored. Nobody at the track that has driven either truck could tell.
https://www.ssl-stormerhobbies.com/c...ns&pn=ORN66045
#1491
So who is running a 540? Anyone? Thinking of giving it a go on a tight track here...
![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
#1492
I have good luck with mine so far. 8.5 does all the big jumps fine. Feels a touch slower than my 4.5 550 that was in a jammin.
#1493
I'm all good on motors but PM me, we can talk.
#1495
Good point made^^^ I'm running on a low bite track. 10.5 in 2wd buggy is more than enough.
#1500
