AKA Tire Thread - Information
#63
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I hate to buy new tires just to realize the tread height is too tall for my application which is med/high bite clay........then we ghost them.....why not make a design with the tread height shorter when MOST guys running indoor on med/high bite clay are not running full-pin?
#64
Trevor: +1 brother. It kills me to see or have to do that to a brand new tire.
#65
#68
Ran the new Rebar rears in soft with the red inserts.. absolutely awesome... These look like they are going to be the "go-to" tire for indoor for me at least.. They are better than Losi pinks and don't wear nearly as fast.. dialed
![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
#73
The inserts are about just as soft, but with akas cut outs in the under side of the insert, it makes them softer when glued up. If you rub your thumb across the two, the akas feel like they'll last a lot longer too. The aka inserts are what I will only use for now in 1:10 buggy.
#74
Wow very tempting to get anew set of tires.
#75
I sold 10 sets in minutes, guys went out glued them up and came back a half hour later and they all said the same thing. Best tire ever. High bite indoor clay track.
These were the soft compound. Red foams feel just like the prolines. Real soft compaired to jc foams.
