AKA Tire Thread - Information
#181
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
![weird](https://www.rctech.net/forum/classic_images/smilies/weird.gif)
#183
what do you guys think is the best all around (sticky clay/loose clay) front tire? if there such a thing... thanks for the info
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
#185
sorry... forgot to mention for sc truck 2wd.
#186
#187
If you use aka tires then super soft wishbone or rebars for sc tires on clay.
#189
I know this is not a 1/8th thread but here's my question, wishbones seem to be discontinued in 1/8 buggy, does anyone know if there being replaced with the rebar maybe?
#191
Still testing compounds, we are really close to nailing it down. I know it has been a long time testing but I am sure everyone would understand that AKA wants to make sure the compound is right.
the medium wishbones are still available while supplies last on the website . I can't speak for Mark or Joel but I am pretty sure there is no immediate plans for 1/8th scale buggy Rebars. I am sure in due time there will be something drawn up for indoor clay (Rebar) type tracks. Possibly 1/8th scale buggy Vektors ![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
Yes, I would imagine either soft enduros or soft Rebars in your case.
#193
Mid-corner stearing, as I understand it, would be most noticeable when turning through a sweeper, correct? If your rear end is coming loose in the middle of a sweeper you have too much mid corner steering and/or too little rear grip, right? I was struggling with this particular example with my SCT at the KO race.
#194
Hey guys. I'm getting ready to glue up a set of super soft Vektors for the front of my 2wd buggy. I have a coule of foam options available right now and am trying to decide what to use:
1.) J-Concepts stock 2wd front open cell - seems to be a little softer and have a flatter profile than option two
2.) Losi stock 2wd front open cell - seems to fill out the tire better, gives a more rounded profile to the tread face, and seems stiffer (supports the tire a little more)
Anyone have any opinions on this? Do the Vektors benefit from a flatter or a more rounded profile?
For reference, my local track is hardpacked and a little damp clay. I'd say medium bite usually also. Thanks!
#195
Good questions and if possible, same feedback/ideas as to what open cell foam to use for the "rear" 2wd based AKA tires would be great as well.
I do have "rear" Losi open cell foams to use, and wanted to see what others have used/thought. (say the "Impact" AKA rear tires in my case.
