![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Thx Casper - 95 degrease here in IN, I've tried
no drag Brake, but then it seams hitting the brake
with my finger is too much and slides the nose, then pushes
on entry too much. Min brake 8, max 70, if I turn down
max then I can't do a quick whip around if I need to.
Drag brake seams like a crutch, so if I just need to
Learn without it I will, but then I go from just making a main
to mid B. whatever the case I value ur opinion
Struggling with motor temps a little,
anyone ever use the FTW fan and carbon fiber mount
It is very close to the solder tabs on the Pro 4 Tekin
540 size. Also I can raise but it mounts over
The center diff which are counter sunk so need
To use some different hardware.
Also Casper, Ryan, Randy, Tyler and others I failed to
Mention, the amount of time and effort it takes to
Share ur knowledge and experience is VERY appreciated
Temps never below 175 and usually 185-190
Situation - small outdoor low bite offroad,
RX8 , Pro4 4600 or SCX4.5, , no timing , CL 80,
Drag Brake 12 ( I really like how it turns in),
Yes I spin the tires, hard not to when so much there
I've tried 12 to 15 / 40,
Wow did you even bother to read my post a few posts back. We're done with that subject. I hate spektrum and you can hate flysky. It really doesn't matter to me. If you wanna hate here's the thread: http://www.rctech.net/forum/radio-el...ing-issue.html
Is the 4000kv good in this truck? Sorry for the question just curious as its weighs more then the other sc trucks
But, it sounds like you have a lot of heat buildup from braking: ie: high drag and high max brake.
When I had the 4600 I think I did min brake 50, and then worked with my EPA to fine tune (to reduce it as needed).
Are you coming into the turns really hot and doing a lot of late braking? Sounds like you're coming in fast, brake, turn, and rocket to the next turn - rinse and repeat. If so that'll eat up lots of energy and create heat. If that sounds like how you're running, and if the changes and the fan don't help, try a little slower entry into turns. Carry the speed thru, then accelerate out so that you hit the next straight with more initial speed.
Question, suspension was stiff in the rear. I reamed a-arms loosened nuts on carriers and the suspensions drops with no resistance. But, when I put the rear sway bar on it seems to slow the suspension movement down expecially when I tighten the two set screws that hold the sway bar to the rear gear box. Is this how it is supposed to wok or am I adjusting the sway bar wrong? Thanks.
IE: if you disconnect the sways from your arms, then raise one side of the swaybar - the opposite side should lift with no resistance.
Gearing should help with temps more then that but if you have a ton of wheel spin this will cause extra heat and gearing will typically not fix wheel spin and gearing down can even make it worse. CL should help some. Driving styles can play a part in motor temps which is why I keep going back to CL.
The motor will run at 200 no problem but it should not need to run that hot. Check to make sure you gear mesh is good and your drive train runs smooth without the motor attached.
Thanks everyone for the help
- FTW fan - move motor, I installed with motor in and actually don't have hooked up yet since it comes with wrong plug , so yikes
- point and shoot - yes that would nail my driving style for the 4wd, not so much 2wd, so yes my trigger finger may be causing
- my radio is the old JR but Losi name on it, can set end points , but radio in my future
- go away from 4600, no way
I like it too much, but thanks for you other advice
- drag brake I know is a crutch and will address that , I should be able to drive without, just newbie on the controls
- running 5,5,3, was running leaked out mush n the front and it actually turned better,,rebuilt and filled with 5 and turn actually decreased
- I'm sure my trigger finger and driving style worth 20 degrees
, I'll pull the pinion and check rolling resistance which isn't bad, but proly time to upgrade all bearings anyway.
Thanks again
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
Thanks again
Thanks again
Thanks again
Check your bearings and the single biggest heat bandit with these things is braking. Lower drag brake to an acceptable value and then ALWAYS adjust your brake EPA for each track to as low as is needed. I usually do this at the end of the straight where I need the most braking and go down as much as possible. For example, currently, the brake on my ESC is set at 50% and on my radio, its at only 70% of that...
