Losi does have an EC5 connector that uses the solid male bullet instead of the bridcage type buy they are like 5 bucks a pair .
I run a 13T pinion on a 1/10 track and temps are not a problem. Actually the way I understand it running too small a pinion on a large track can also cause temps to rise because the motor is revving high all the time. You have to gear for the track you are running on. What size is it?
What would be the right current limiter setting? Would that help lower temp?
I would drop to 13 and see how it does. Could also be other things like too much wheelspin from a current limiter set too high.
drop to 13T if you have one available and on a smaller track i would think 60-70 is where most run the CL setting
I run a 15 tooth pinion on the same esc/motor combo and truck. Thats on a mid size track. It comes off at 140. Im running no limiter but I dont continually hammer the throttle either. Using alot of brake can heat things up more too. When I went from 14 to 15 my temps were nearly the same or alittle (2-5 degrees ) lower. I think too many are gearing this thing like a brushed motor. Its a torque motor and if you keep it in it power band it will run cooler and more efficient. Also check to see how much rolling resistance your truck has without the motor in. If it rolls a ways without the motor in then its not the truck causing the extra heat.
All of the them are good. Pick which one you like.
I have owned both the BCE and KH. Running KH now
ProMatch to the rescue: They sell EC5s M/F with the solid male bullet for $2/set plus you can buy just the males or just the females for $1/set (meaning 1 housing and the 2 required terminals).
I need help! :O
What's up guys - I've had this truck for a while and love it. I just found out that my track allows 3s, so I bought one to stay competitive. I just can't run it, though. Temps are nuts. I have a TORO 4x4 SC ESC and the 4000kv 550 motor:
http://www.ultimaterc.com/forums/sho...d.php?t=137055
The popular Tenshocks are rebrands of these.
I ran for a little over a minute on my track with this combo and a 12t pinion. Motor got to 160 with a MASSIVE heatsink on it, and the ESC got up to about 150. Dang! I have some cheaper 4mm bullets between the motor and esc, these got to 150* as well. This is with punch control at 50% and low timing. Sheesh!
Got a few questions.
1. What role do the cheapo bullets play?
2. Does punch controlling actually raise temps?
3. Shouldn't regular 12-14 guage wire be able to handle 3s? Is it normal for it to get hot?
4. What kind of motor would I need to run comfortable temps on 3s in this heavy pig? Is it possible for a 550?
5. Is it ok to adjust timing on sensorless motors?
Thanks a ton, guys. I really appreciate the advice!
I need help! :O
Would 5-7-3 be a good carpet set up?
I posted last week about smoking my pro 4 and asked for suggestions about what motor to buy next. Thank you to everyone for their input. I was fixing to order a tenshock when I decided to call tekin. I told them what happened (rotor delaminated) and that it was well out of warranty. I asked if it was worth sending in or should I just buy a new motor. I was surprised when he told me to def send it in that if was not able to be repaired they would swap it for a brand new one for $73. Also about six months ago I had a problem with my rx8 which they had just repaired. I called up and told them that I had a big race the following week. They shipped me out a brand new one that same day for $165 and then refunded the money on my card a couple of days later when they received the one I sent back. I'm not knocking any of the other brands but to me that kind of customer service is worth spending the extra money on. I guess its official, I'm a Tekin fan.
R/C Tech Elite Member
They are definately a class act in the RC biz for sure!
I need help! :O
scte torque rod
hi,
anyone mod the stock chassis for the torque rod? mine doesnt line up anywhere so i used a rc8b aluminum rear brace (modded) to stiffen the rear.
ill end up with a new flex chassis to accept either brace but is there in fact a new hole needed for the torque rod on the stock chassis?
mip bypass shock kit is epic by the way..........
