pro4 4000 - ditto
ditto... dialed in pro4 4000, PLENTY of power on medium-sized indoor high-bite track (60x135) with 14 or 15-tooth on tekin rx8 controller. Tons of torque (almost too much, not sure how you guys are getting 4600 power to the ground!), stormerhobbies.com has them in stock $135, got mine shipped ground to TX got here in 2 days. TL 80, brakes 50 (I think) otherwise just stock ESC settings.
Too many variables to say exactly, From what ive weighed at our local club, anywhere from 6lbs 2oz with a few mods to Heavyweight's with Dual shock towers out back and Extra Shoe goo'd body's at around 7lbs
Looking for help here. I want to get new ESC and motor for my scte but not sure what to get. Mamba or Tekin. Im new to the elect racing. Have the Novak 550 but I dont seem to have the speed or length of batt life to get a 10 min race.
Batt is a 5300mah 50c
R/C Tech Elite Member
Thats exactly what everybody has been asking... Take a look at the last 3 pages...
I did buy again ,I have two!!
GOT IT?
I saw posts for the RX8 thats a 1/8 scale esc but why use that with a 1/10 motor? Just curious. like i said im new to elect
Because it is Overkill!!And this truck is more like an 1/8 scale than a 1/10 scale! And the 550 motors really are not an 1/10 scale motor and the 540`s are barely 1/10 scalable
We had a fun night of racing at OCRC tonight. There were several fast guys in attendance from rctech...
In the mains...it was the Losi SCTE, in the top 6 out of the ten drivers...
Casper took the win with a Tekin Rx8 and Tekin 4600
Kevin (me) took second with a Tekin Rx8 and Tekin 4600
Scott Kelley took third with a Tekin 4600 and a SC8 speedo
Hacker07 ( Ryan ) took 4th , after his car shut off , while in second, but ran great..
Ryan runs Viper speed control and a Viper 550 motor.
is shoe goo just good for preventive maintence for a body or will it fix a body too. if it will fix bodies do you put it on over the body or under the paint? or is it best to use on the underside of body directly on the plastic?
does it dry clear and paintable if applied directly to the underside??
any help from the guys that have used this would be greatly appreicated!!!!
got a few weak spots on the scte body I need to touch up!!
I have the Pro 4 4000 on my newest Losi 4x4 and it was reaching 180s in temps after 5 minutes with a 15T and 16T. What pinions are you guys running? I am using a Novak Kinetic ESC and 2s 65C batts. The ESC stays about 120-130. Could the ESC be a big factor in the heat of the motor? I'm planning on getting a RX8 but LHS was out of them.
Scott Kelley took third with a Tekin 4600 and a XERUN 120amp speedo Fixed
DANG IT!!!!! Well that's a lot better than the esc like you originally thought! Good seeing you tonight Ryan, thanks for your help as always!
