![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I’m racing my Ten-SCT on Pegasus Hobbies in Montclair, CA. The track is dry (constantly being watered but the track absorbs the moisture quite fast), not exactly perfect with quite a bit of bumps, dusty. I’m currently using Proline HoleShots and Snipers both with soft compounds (M3). Any suggestion/s for better tire/s for this particular track?
What do you guys think of Proline Bow-Fighters and their new Blockades?
Thank you for all your suggestion/s and input/s.
Give some Gridirons or Enduros in soft compound a try. Try supersoft if traction is low.
![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
Yea ive gotten away from using proline tires and have liked aka stuff much better
The Aka's for SC are much more consistant than the PL stuff.
...thank you very much for all your tire suggestions =) I really appreciate all the help!
I ended up purchasing soft Enduros. Unfortunately, they didn't have stock on super soft compound =( ...I hope it won't be too bad though and that it'll still be an improvement to my previous tires.
Thanks again!
Thanks again!
In my experience the Super Soft have a little more traction but wear alot faster than the softs. I think you will be happy.
It boils down to outside temps...higher temps use soft, cooler temps super soft.
I ran Soft up front and SS in the rear. As temps start to drop at night out there I think SS will be better but S will last longer.
is there anything the has to be done to the scte out off the boxe to run it i been reading the about the pins and diff grease . are this problem on the early kits only . have one here with a rx8 and a por 4 4600kv what do you guys recoment.
I snapped the Jammin Product Carbonfiber Rear shock tower. ![Embarrassment](https://www.rctech.net/forum/classic_images/smilies/redface.gif)
I will admit tho, i was pretty rough on the truck. But I will never buy Jammin product products for the losi again.![Mad](https://www.rctech.net/forum/classic_images/smilies/mad.gif)
I have a TLR kit on the way. Hopefully these will be a bit stronger.
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
who is using what to shim the front and rear diff side to side movement? the part # in the manual is no good.
