Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
That and or longer rear links.
I'm looking for some setup help. The problem I'm looking to get rid of is mid corner to exit, on power my car has a tendency to want to over steer instead of squaring up and powering out. I find myself counter steering because It just continues to rotate. I have played with diff oils a lot and have found I prefer lighter oils because when ever I go 10k or higher it makes the car to twitchy for me. My set up right now is 5k front 3k rear
Front
Long link 2 mm washer on knuckle
Middle on tower stock caster blocks
Inside lower hole on tower for shock position
Out side hole on arm
Rear
Middle on 1* hubs
Inside lower on tower
Inside arms with 2 mm in front and 1 mm in rear
Hubs forward
3 right side up on toe insert
2nd hole from top on shock tower for the shock
Inside hole on arm
Front
Rear
Middle on 1* hubs
Hubs forward
Inside hole on arm
this might help. I am running full droop (I don't have the droop screws in the arm)at the moment because I broke a rear arm and threw it away and forgot to get the droop screw out, so I just pulled the other one out. Maybe I will just limit the rear shocks internally with 2mm of spacers and see how it goes. What is the shock length (eyelet to eyelet) that most of you are running?
OK, once again, Durango Noob Question… My local shop has the stock 87 tooth spur or the 81. Which should I go for and what Pinion? My local tracks are pretty good size with long straights.
I'm leaning towards 81/26 combo but please bestow your knowledge on me.
I would start with 81/21 or 22 on an orion 6.5
Another new Durango owner here. Received my 410r today and after reading through many pages it seems rear traction may be an issue. My question to all of you owners is, all else being equal, which of these diff fluid setups would yield the most "calm" rear end that doesn't want to step out on acceleration?
10k/10k
10k/5k
7k/3k
I know that many other factors play into this but I would like to get a good jump on things with diff fluids right off the bat.
No racing, just playing around on less than perfect track conditions.
Thanks All
10k/10k
10k/5k
7k/3k
Thanks All
10k/10k
10k/5k
7k/3k
Thanks All
10k/10k
10k/5k
7k/3k
Thanks All
The 21° blocks settled the entire car down for me. More stable at speed and more predictable IMO. It might not directly help with snap oversteer but I was having that problem and now I don't seem to be (as much) and my lap times are greatly improved.
+1 also made the car smoother on long sweepers.
That's one sick buggy, son.
Anyone know of a hobby shop that's got old style rims they need to get rid of? My 2010 DEX410 is still going strong and I figure there's no need to update to the new hex adapters if I can find some of the old rims.
Thanks!
Thanks!
![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
Anyone looking for a Lunsford ti turnbuckle ballstud/ballcup kit I have one for sale..
http://www.rctech.net/forum/r-c-item...uckle-kit.html
Does anyone know of a place that has decent shipping to Canada with "TDR310112" in stock?
Most of the places I order from are all out of stock. Most other places want to charge $20+ for shipping..
