Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Thank you all for all the information, will buy mini pin and 2WD front tires to rock and roll!
why 2WD fronts? I have never seen 4WD running 2WD fronts as they are very narrow. get standard 4WD fronts (rear are same for 2WD and 4WD)
i've seen guys do this because it stretches the tire making it more square and allows for sharper response. just like you'll see 1/8th guys do from time to time (they cut out a few mm from the middles and glue them back up)
On the V3's are the shocks same from R to non-R?
I am just now building a 410r that I have had for over a year. I can barely get the diffs to turn by hand. Any suggestions?
sounds like you need to add another diff gasket.
It feels like the gears
Are too mashed together to even turn. Are there shims, or what do you suggest?
What I don't recall any shims included or needed.
When you put the Sun gears on the hex at the end of the outdrive, did you file them down for a good fit ? Its often very tight, so i file the edges of the hex so they slip on all the way, and actually come off to for maintenance.
