Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
@mesa80 This sounds like your chassis is scrubbing up the jump face. To do a quick check raise your ride height and re try the section/jump.
WELL RANDY I SET MY RIDE HEIGHT EVERY TIME BEFORE I RACE IM RUNNING 20.5 MM FRONT 21MM REAR AND ANOTHER THING THAT SUCKS IS IM THE ONLY GUY THEIR THAT RUNS ALL DURANGO STUFF I WENT TO RACE THIS PAST WEEKEND AND COULDN'T GET ANY TRACTION WHAT SO EVER SO FIGHTING MANY DIFFRENT ISSUES FOR DAMP CONDITIONS WHAT TIRE DO YOU RECOMMEND AND I KNOW WHEN I LAND THE TRIPPLE MY CHASSIS SLAMS THE GROUND
First off the "caps" thing is going to annoy everyone, fyi.
That being said if your setup is too soft the car regardless of ride height can scrub into the jump face causing you to lose speed.
Raise it up to 23 and 24 rear and give it a go. It takes 30 second to adjust it and if I'm right you'll simply need to make a spring/shock change to make the section.
Because "caps" on forums is generally interpreted as a raised voice or yelling.
I worked in that industry as well and know ADP and other systems require caps. Stop screwing around and get back to work
![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
Saw this over on Oople.com
Center diff-like slipper?
![](http://i999.photobucket.com/albums/af118/abodesofas/Screenshot2012-05-28at091244.png)
![Thumbs up](https://www.rctech.net/forum/images/icons/icon14.gif)
I really wasnt aware of the caps thing im off of work and think im ready to attempt some set up changes and try them tommorow thanks randy any more advise would be appricated will get back and let you know how it works
Dex410V3 Ready to go next Saturday fever.
S&N Trackside
Here are some pics of car and some wiring. With the right electronics space is not an issue.
I really look forward to owning one of these.
just bought a used dex410r.
started going thru the diffs and found the orings leaking a chipped gear.
couple questions if someone could help?
1- is there a better sealing/wearing gear diff oring?
2- if i get the machined 42t gear,is there a maching dive pinion gear to replace?
thanx much...
thanx much...
Hi,
I totally messed up the original body trying to airbrush it, rookie mistakes over and over....
So, I'm looking at the proline 2012 bulldog and found also the gainabull, is it really worth $40 for the gainabull? Does it looks that good in person?
what shock oil for racing? still building mine..
love the big bores and quality/build of this buggy very well designed glad i got it instead of the B44.1
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
