Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Diff seals are perfect for me. No leaks at all. Have about 20 packs through the car, including a few diff oil changes.
I broke a few rear hubs when I first got it, and one rear hinge pin. Replaced and all is good now.
thanks a bunch yeah ill go for a test drive at my track..people there have both of them..
if i do get this buggy..
hows the diff leak on this buggy? seals up well and last ? what do you recommend for race ? im looking to put a 8.5 motor 9.5 or lower..
have a TT ofna that leaks front/center/rear thats why i dont want to do all that messy diff too..dont use it anymore just have a 22 buggy..but this buggy only has 2 oil diff to maintain so i think ill be good as long as it dont leak easy and will last for a long run..
also whats common thing that breaks? pretty durable buggy? i only use my buggy for indoor track only not a basher
thanks
thanks
For the 410v3 (not the R), I'd get the rear Alum diff Hoop and Alum Servo Saver Arm. have a spare set of Front Inner hinge pins , maybe some front arms, and rear hubs (I've heard people break em). And your good to go. Most people agree the buggy is very durable.
thanks
thanks
So as others had suggested,try driving one first before you decide, at the end of the day it really depends on which application ( well for me , for my 7 yrs/old son), so DEX410 (for me ) is a Tank. hands down.
BTW, my son is using a 6.5T Tekin motor so you could just imagine the insane power the car has to endure plus the driving skills.... hahahha....
Location: Queensland, Australia, Earth, Galaxy, Universe, A Childs Sandpit
Trader Rating: 42 (100%+)
Does anyone use the shock boots, the outdrive boots and the axle boot and if so how do you find them? Not to much of a weigh down in power with a 1/10th scale car?
I've read through many pages in this thread and the biggest concern is the diffs? The V3 has awesome diffs. Had lots of pack through mine and still do not have a diff leak. No special seals...just box stock stuff. (I did add a little #3 permatex to the diff halfs just for added insurance.) Not even a drip......anywhere!
As far as the difference between gear diff and ball diffs. Yea you can tune a ball diff without removing it from the car. But to find the same consistency after a rebuild is super hard. For the gear diff I know what fluids are in it already and when its time for fresh oil I clean the old oil out and add the fresh stuff. Same feel every time. No springs, bolts or nuts to worry about breaking or coming loose. Please don't even get me started on the plastic gears on the "other" brand, or the amount of broken shock shafts or broken shock bodies. Yes....stuff breaks. It's a race car....but I see a lot less DNF's with the Dingo than I do with "other" brands.
Your biggest concern shouldn't be whether its like the "other" car (it isn't, not even close)....it should be trying to keep the smile off of your face while driving the thing, so the other racers don't know about the gun you brought to the knife fight!
Just saying.....
Just saying.....
^ agreed!!! :>) V3 on the way. Should have it tomarrow.
They are useful when running on dirt, keeps the shocks much cleaner and the driveshaft joints wear less (as you can lube them and not worry about dirt mixing with the lube).
I can tell you Ray that the first set will be on the stock wheels but after that we will see, And thank you for the kind words sir.
Zippy (STICKERS) Did you figure out the esc problem?
Oh and 210 Not going to happen
Famous last words. Working on a few things right now....give me a bit of time and you can drive mine. Coming from the car your running I must say in the short bit of time I've had my 210 it corners better and jumps better. As soon as I can nail down the consistency then it will be dialed. The car reminds me of the SP2 before big bores. ( IMO K big bores made things complicated on an already awesome design.)
ok ordered the V3
should be in friday with a 6.5 cant wait
.. now my questions
1. what oil diff for track use? for front and rear..
2.what shock oil wt front and rear? i know depends on track but i just need an idea what you guy use..
3.what pinion gear for motor on 6.5? i looking for something not super high speed but yet something that has pull/push for them corner turn with jumps/whoops ect...
4.also some hop ups...i see that the rear dont have alumin hub carrier like the front..looking to get the rear later on as i build and run from there.. as for what degree..also part number or any other brands that have nice alumin upgrades that offer diffirent colors ect..
thanks..
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
thanks..
