Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
So I just sold my B44.1 And am thinking of picking up a dex410r v3 for next winter indoor season.. So I have a couple of questions.. What is the difference between the 410r v3 and the 410 v3? What are some good hop ups for the car to give it better durability and performance? What extra parts should I always have on hand? Whats the tallest pack it will except?
Im not trying to be a d#"k but:
I suggest that you have a look thru the last pages, it has been covered a few times since the V3 has been released. If you skip all the complaints about parts being available you will find your answers.
Or someone else can jump in and give you the easy route
Location: Queensland, Australia, Earth, Galaxy, Universe, A Childs Sandpit
Trader Rating: 42 (100%+)
I've just about finished my V3 build and I have a concern about the diffs. Do they leak without a gasket installed? I didn't get gaskets in the kit and I am wondering how well the diffs seal and keep the oil in.
![Cool](https://www.rctech.net/forum/classic_images/smilies/cool.gif)
nope no gaskets in the kit they seal really well. they may leak but that might be from the orings only
use black grease. my v3 started to leak after a few crashes that tweaked the diff housing. using black grease even with old housing seals the leak
No need for gaskets, if you use some black grease or green slime, the V3 has the DNX Shock O rings which are as good as the Kyosho P5 rings we all used in the older v2 kits. Also put a little grease/slime where the gasket "would" be (i.e like a 1/8 diff build) that'll help seal em.
On another note, just finished building my v3. Added rear diff loop and Servo saver crank (tresrey). For lipo i ordered from hobbyking and a trackpower pack. The trackpower is 25.1 tall and fits with no issues. For dirt tracks I have a set of calibers and a set of goose bumps. I'm still waiting for a savox servo replacement and hook it up to tekin for some tweaks.
So tires/shock oil/diff oil for carpet? Thanks
I use Permatex #2 non drying gasket maker on all of our Durango diffs. Works awesome and only costs a few bucks for a tube of it.
All I know is if this class starts up around here I'm picking up one of these..
LOL I'm open minded if someone had one.around here for.me.to.try.
Anyone??
I'll take that advice for the losi scte center diff
Front shock 2 holes 1.6 losi 45 wt, rear shock 3 hole 1.6 30 wt losi
front diff 10000 rear 3000.
