Like Tree22Likes
Old 05-04-2012, 06:41 PM
  #10276
mnracer's Avatar
Trader Rating: 29 (100%+)
What shock pistons are preferable front/ rear?
mnracer is offline
Old 05-05-2012, 08:02 AM
  #10277
Woulvesbaine's Avatar
What pinion?
So I just bought a 410 from someone here on tech.net. It's missing a few things including a rear hinge pin and an aluminum spacer as well as a pinion.
It came with an 8.5 motor and a TEKIN RS esc. I will probably eventually switch out the RS for a PRO that I have in my 2wd (no need for the pro there).
However for the time being, what pinion should I try? I think it came with the stock center spur, but I am not 100% sure. Clay track. Would rather go a little lower on the pinion as I will not need all that speed and I would like to keep the temp down.
Thanks in advance.
Woulvesbaine is offline
Old 05-05-2012, 11:00 AM
  #10278
Trader Rating: 26 (100%+)
Default Dex410 battery installation
Do you really have to remove the rear diff to install your batteries? Just bought the car and it's all I am seeing
Ssilverfz1 is offline
Old 05-05-2012, 11:27 AM
  #10279
No need to remove the diff, remove the spur gear using the clip and the battery clip then the batteries come straight out.
http://www.youtube.com/watch?v=ICFAazuVxHg
Hope that it explains it.
Chris-s is offline
Old 05-05-2012, 11:34 AM
  #10280
FrEaKiShTuNER's Avatar
Trader Rating: 200 (100%+)
+1 I was in the process of replying when you posted..
And Silver, I hope you enjoy the car!!
FrEaKiShTuNER is offline
Old 05-05-2012, 11:38 AM
  #10281
I am thrilled with the car......the only downside to buying already assembled is not knowing exactly how it all went together thanks for the assistance.
That was simple and so much easier to change gearing......compared to the old B44 I had.......I am very happy to have switched brands. I bought a 210 as well and sold all the associated stuff
Old 05-05-2012, 11:52 AM
  #10282
Year I hear that.. I bought my first 210 assembled. And it was a bit of a headache to tune at the track. So I picked a weekend and tore it apart and rebuilt it. That way I knew how everything went together..
Old 05-05-2012, 06:34 PM
  #10283
hotdognobun's Avatar
Trader Rating: 32 (100%+)
anyone try this for the dex410 V3?
http://www.tsrproducts.com/index.php...71270rd-t.html
hotdognobun is offline
Old 05-05-2012, 06:52 PM
  #10284
R/C Tech Elite Member
Trader Rating: 520 (100%+)
Originally Posted by hotdognobun
I use the Tresrey hoops, the V3 diff cases already have bearing spacers built in, so I think maybe its intended for the older model 410's ?
flame56mx is offline
Old 05-05-2012, 07:56 PM
  #10285
Trader Rating: 79 (99%+)
The Tresrey hoops are the bomb. As are all the of the Tresrey parts.
Raul Garcia is offline
Old 05-05-2012, 09:30 PM
  #10286
Thank you Gents
Old 05-06-2012, 04:16 AM
  #10287
dexon555's Avatar
Thank you Gents
Nice avatar.
dexon555 is offline
Old 05-06-2012, 09:07 AM
  #10288
Smile
Originally Posted by dexon555
Nice avatar.
Giggidy.....
Old 05-06-2012, 02:33 PM
  #10289
subaru_tech's Avatar
Trader Rating: 106 (100%+)
newbie to durango.can you some help.
looking at getting a 410.although i see there is many versions.
question is what are the major diffrences in models.
dex410 v3
dex410 2010
dex410rv3
dex410r
dex410
i think these are all the versions i have found searching.
subaru_tech is offline
Old 05-06-2012, 02:39 PM
  #10290
Jpm1's Avatar
dex410 v3
dex410 2010
dex410rv3
dex410r
dex410
The v3 versions are the only ones available new now and if you can afford it the 410 v3 is the one to go for as it has all the hope-ups and big bore shocks as standard, if your on a budget go for the 410r v3 but if your a below average driver expect to have to put a few alloy upgraded parts on as you crash.
If your going second hand I'd try to go for a 2010 spec as they have all the hop-ups but the small bore shocks like the 410r v3, which still work very well if your track is relatively smooth
Jpm1 is offline
