Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#2926
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Im looking forward to seeing kinwald do sum damage with this car!!
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
![Cool](https://www.rctech.net/forum/classic_images/smilies/cool.gif)
#2927
keep us posted on that. it sounds like a solid idea. im also concerned that the friction from the out drive rubbing the washer may cause enough heat to melt the edge of the diff cup. i noticed tonight that the diff cup where the out drive goes thru isnt metal like on a 1/8. the extra play on the out drive might be there purposely. keep an eye on it and keep us posted.
#2928
ok so I know for sure to use P5 seals in the diffs, now as for shimming like a few pages back, are you all doing that?
I know the one guy said on the out drives, can someone show me where exactly on the outdrive?
#2929
just put them on the outdrive, and slide than put the outdrive in the diff like normal so the shims sit outside the outdrive.
you need 1 7x10 and 5x7 shim on each outdrive.
#2931
or dremel a line through it and take it out with a screw driver?
other than that is to use a screw extractor or new diff case
#2933
Is anyone using shims anywhere else in this car?
#2935
So my wing is taking a beating. i was thinking about getting a losi 10t rear wing and seeing if i could make it work. it made out of a harder plastic not lexan. i realize that this will put more strain on the wing mounts ina crash does anyone know the wing dimensions on a losi tenT rear wing. my best guess is about 8 inches wide little wider then the stock rango wing
#2936
#2937
#2938
This wing might be better for a rango although i still have no idea how wide it is
its for a kyosho dbx i would post a link but i dont have enough posts
Part# KYOTR101W
Part# KYOTR101W
#2939
Here is the one I was mentioning if you cannot find anything else in stock . . .
http://www.toadztoyz.com/RC-BODIES-W...-p7701887.html
