Kyosho Ultima RB5 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Hey guys what Losi BB springs are ya'll running front and rear...i'm running on a outside medium high bite clay track! Thanks
I turn the tire inside out and use a small, sharp pair of straight scissors. Some people like to use curved lexan scissors for this, just personal preferance, either gets it done. It doesn't have to be perfect, and if you cut too far into the bead you can just back up, straighten out and continue. It will get fixed when you glue up the tire. If the bead is too short and thick to trim (some Losi fronts are like this) just trim the corner off.
About to take a dive into the Rb5 wc coming from a 22. What necessary hop ups or changes should I make to the car coming out of the box?
Need some advise on the best esc for spec (0 boost ) 17.5 , 13.5, classes. I was out of the game for a bit and have older tech esc's (lrp sphere tc, and gtb's). thanks.
the car is very tough stock. However if you feel like adding hop ups, I would in this order:
Kyosho aluminum sevo horn
steel or alu hollow balls for the shock ends
Aluminum suspension mounts
Aluminum rear hubs
I would build the car with UM511 shock tower from the SP2 car. If you are on a smooth med to high traction track, also add 2mm internal limiters to the front shocks with the 511 tower.
Aluminum rear hubs
Aluminum rear hubs
check radiocontrolzone.com/showthread.php?t=260988
I think these will fit. Says RB5, fit sp2?
Whats the difference between the front BB shock tower and the WC i am trying to eyeball the 2 together and the only thing i can see is the BB bottom bulk head mounting holes the top 1's is counter sunk
can any one help me out
cheers
cheers
Quick question on the factory RB5 ballcups.. are they the same cup size as the classic RPM ones? Trying to figure out if I need to buy RB5 specific ball stud size from lunsford... or if I already have them.
Hello!
Which upgrades do you drive with the sp2?
http://www.lunsfordracing.com/mm5/me...CARS-KYULRB5WC
i had a heck of a time threading the kyosho ball cups onto the rods, i ended up using the ball cups that were in the lunsford bag
Guys what pinion you suggest with a 75 spur and 13.5t motor or 9.5t?
