Kyosho Ultima RB5 Thread
hey guys what pinion should I use with a 8.5 motor?
How is everyone running the spacers on the new UM569 steel front axles?. I see that if I run 1mm on the outside and 2mm on the inside like the manual says my front end will be 2mm narrower that I was running before. Should I just put all 3mm on the outside? Anyone found a setup sheet for a WC yet?
I see on Tebos set-up sheets for BB's, he doesn't use internal limiters. But also he doesn't give a shock length.
Does this mean he just has the 97038 eyelets fully threaded onto the shock shafts?
[QUOTE=1;10005047]I see on Tebos set-up sheets for BB's, he doesn't use internal limiters. But also he doesn't give a shock length.
Does this mean he just has the 97038 eyelets fully threaded onto the shock shafts?[/QUOTE
Are you running on a smooth track or a bumpy track? And which front tower are you running? Smooth track requires less droop, bumpy track will need more
i wondered this as well, but them all on the outside to keep the same width as before
[QUOTE=savageboy69;10005071]
UM511. Both smooth and bumpy. Looking for a baseline here.
So is Tebo threaded all the way in on the set-up sheets? I notice that others are 4-4.5 turns wound out.
I think his setup runs the longer eyelets, but again its gonna depend on the type of track you run on
hi all
sorry i know its probably been answered before but here it goes.
i will be running this RB5 SP2 WC in stock class 17.5 no boost on an out door track that can be dusty at times with a few good sized jumps the buggy has been setup as per manual and ill run it that way until i get a good feel for it.
my question is do i need weight? how much and where to place it
cheers
cheers
anyone know of a good gearing to start with when running a 10.5 brushless on a tight track?
also if i get the WC slipper plates and pads for my SP2 do I need to get the WC spring also?
