Kyosho Ultima RB5 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
hey guys, just got the wc! what setup is everyone running on the new car? Im going to run it at the spectrum race at trackside this weekend. thanks!
well for me it was time for "enough practice" today i went live for racing with the wc. 4 hours of practice and tune which i used to dial in me lrp esc and motor that i got monday and 1 broken right rear hub carrier on a landing after the triple. of all the places on the track to have it break. i had some spares that i had stocked up on of sp2 parts and i put in replacement carriers and soldiered on.
the buggy is better then me
thats for sure. im liking what its doing and it is fealing "very neutral" not sure how else to explain it. i like it but im slow on the trigger and some of the corners i do with it are quite embarrassing while others i might as well have a freight train horn blowing and shout "out of the way, out of the way !!!"
![blushing](https://www.rctech.net/forum/classic_images/smilies/blush.gif)
oh yeah.
im going to replace the rear hub carriers with metal ones in an order tomorrow. i would also like to get the rf and rr arm suspenders. but i cant recall where i read it. something about using plastic bushings with the metal rf and rr suspenders instead of the metal bushings that are in my wc box. anyone have a stock number of what this plastic bushing is please?
just checking to see if i found my own answer... are these the plastic bushings? http://www.amainhobbies.com/product_...Bushing-8-ZX-5
Last edited by apriliamille; 11-30-2011 at 09:57 PM. Reason: might have found the answer
I need some set up help with my buggy, its last years model but has the 8mm extension and losi big bore shocks, I am having trouble on the clay as the buggy is loose on the throttle, pushes on and off the throttle and spins out like crazy. I dint run the car on clay till last week, it is fringing dialed in the dirt and asphalt but as soon as I hit the clay it was a disaster. Running 27.5 front and rear, shocks laid in front and rear , 3 degrees toe, ride height 24 frt 23 rear, rear camber link inside outer and middle on bulk head, front link inner hole on block and inner hole on bulk head, running little to no anti squat, med length rear arms, rear hubs .05mm forward, tires were pink taper front and pink bk bars rear. I was really disappointed and need some clay advice. Oh the front link 1mm spacer and the rear link is 1.5mm inner and 2mm outer, the outer rear blocks are 1 degree of toe. The droop I set to Tebos clay setup but can't remember the droop but has been excellent on all terrains. There must be something I can do to get the car to get that rubber squeel like the other cars I was racing. Thanks for any advice.
I am running the Mcduffie setup with one change including the arm mod. middle hole on rear tower
I want to get more off power steering. any suggestions? it doesn't rotate as fast as I want it to.
Mcduffie what do you suggest? I have 21 grams in front weight.
tires are scrubs up front. suburbs in back. version 2 unfortunately
![Frown](https://www.rctech.net/forum/classic_images/smilies/frown.gif)
I would go outside on the rear tower and lower the front ball stud to 1mm instead of 1.5. What front foam are in the tires?
Is the SP2 non WC still a good buy? Cant quite justify the price of the WC when I'm mainly using it as a fun car as no one seriously races 2wd where I am.
Could anyone who has driven the Losi 22 or DEX210 able to compare it with the RB5 SP2? All three are around that same price, so it a tough choice wether to go for the new kids on the block, or the older proven model.
been looking at the kyosho for a bit now. Been racing a 22 for 6 months and all I can say its very rugged. Havent broken a single part. How the kyosho on durability.
so in the front i am essentially limiting the droop a little Brian?
also, i have no weight in the back besides the 10 grams by the receiver
the front ball stub washers have on effect on droop... lowering the front ballstud down will make the front react a little faster..
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
T
thanks guys.
Josh, were you at WC the other day?
